Hey everyone,
New member here looking to seriously purchase a 2010-2013 Q7 TDI within the next ~2 weeks to replace my B7 A4 2.0t.
My budget is around $13k(want a Prestige ideally)- which is why I'm looking at these years. I've found out that for 2013(CNRB), apparently the engine had a slight redesign with 2 fewer timing chains, weighs 55lbs less, and just 15 more hp(negligible), and better fuel economy(does anyone know how much better?)
I'd like to do most of the maintenance myself(as I did with my gas 2.0t), and this will be my first diesel vehicle, ever. My concern is reliability. I haven't been able to find much information about CATA vs CNRB reliability wise. In terms of the engine specifics, I found this below at ClubTouareg.
Are there any other differences? Do both come with 8 speed transmissions? If not, what years do come with the 8 speed? Many thanks in advance!
The 3.0 TDI. Audi is only applying the new second-generation 3.0-liter TDI in the models currently on sale in the US: the Q5, Q7, A6, A7 and A8. The engines are paired with 8-speed Tiptronic transmissions.
The first generation 3.0L TDI delivered 225 hp (168 kW) and 406 lb-ft (550 N·m) of torque; the current second-generation engine is 55 lbs (25 kg) lighter (from 458 lbs to 425 lbs), and delivers 240 hp (179 kW) and 428 lb-ft (580 N·m) of torque. (The Gen 2 engine is also a bit shorter than its predecessor.)
The company had set a number of development objectives for Gen2 of the engine, said Axel Macher, head of Thermodynamics/Application V6 TDI at Audi in Neckarsulm, Germany. These included:
Higher power and torque;
Lower fuel consumption;
Meeting ULEV2 emissions;
A start-stop system;
Minimized weight;
Compact design;
Acoustic refinement;
Modular construction;
Optimized driving dynamics; and
Optimized production time.
Audi took 26 lbs (11.8 kg) out of the crankcase, crankshaft, main bearing frame and upper oil pan—the last by switching from aluminum to magnesium. Macher noted that Audi has a new machining process that allows them to make a cylinder bore that will be perfectly round when the engine is operating. “If you have a perfect round bore in engine operation mode, you can reduce the pretension of piston weight, and that reduces friction,” Macher said. Laser smoothing of the bores also reduces friction.
Further contributing to a reduction in friction was going from four chain drive chains to two, as well as a reduction in weight of 8.8 lbs (4 kg).
For the second-generation, Audi further optimized the turbo with integral insulation and by moving away from flange-based mounting to the exhaust manifolds to an integrated component. Reducing thermal mass, it enables the turbo to reach operating temperature more quickly in the heat up phase. Audi also specifically optimized the turbocharger for the North American market to deliver very quick performance off the line. (A design target that appears definitely to have been met, at least subjectively, based on our experience in the TDI vehicles.) In Germany, Macher noted, the turbo is optimized for longer stretches of high-speed autobahn driving.
Tdi1
Changes in the exhaust manifolds and turbo from Gen 1 to Gen 2. Click to enlarge.
Injection pressure in the Gen 2 3.0 TDI is raised to 2000 bar, helping increase the power output and reduce emissions. The piezo injectors also use a multi injection strategy—two small pilot injections, followed by the main injection, followed by a post-injection. This strategy contributes to the quietness of the engine.
You need high EGR rates so you can reduce 70-90 % of the NOxemissions. With the second generation of the diesels, we have a bigger EGR cooler, we have tubes with a bigger diameter, so we have less gas flow resistance. This helps us to make better fuel economy and good emissions.
—Alex Macher
Tdi2
Cooled EGR system. Click to enlarge.
Tdi3
Exhaust gas aftertreatment system, shown in an A7. Click to enlarge
