REVIEW OF OPERATING DATA ACQUISITION FOR THE TDI ECU VIA THE MAF SENSOR IN THE INTAKE TRACT
One of the most important variables used for determining injection quantity and timing in the Volkswagen TDI direct
injection diesel engine is the engine's load state. An air flow sensor is the main load sensor to monitor engine load.
The MASS Air Flow Sensor (MAF) is located between the air filter and the intake tract where it
monitors the volumetric flow rate [m3/h] of the air being drawn into the engine. Air Mass Meters in Direct Injection
Diesel engines fall into two categories, the hot-wire and the hot-film air-mass methods (although some substandard
rice machines have been known to use Hot-Pants Air-Head meters instead! hehe). The VW TDI utilizes the latest in
BOSCH Motronic electronic engine management systems, which is the Hot-Film Air Mass method. Previously, the
Hot-Wire Air-Mass method had been in use prior to the development of the latest Volkswagen TDI engine design.
Either of these Air Mass Meters operate according to a common principle, which is an electrically heated element is
mounted in the intake-air stream, where it is cooled by the incoming air. A control circuit modulates the flow of
heating current to maintain the temperature differential between the heated wire (or film) and the intake air at a
constant level. The amount of heating current required to maintain the temperature of the wire or film thus
provides an index for the Mass Air Flow (MAF). This concept automatically compensates for variation in air density,
as this is one of the factors that determines the amount of warmth that the surrounding air absorbs from the
heated element.
HOT-WIRE AIR-MASS METER:
Previous diesel engine designs used this hot-wire method. The heated element on the hot-wire air-mass meter is a
platinium wire 70 microns in diameter. A temperature sensor is integrated within the hot-wire air-mass meter
to provide compensation data for intake-air temperature. The main components in the control circuit are a bridge
circuit and an amplifier. The heated wire and the intake-air temperature both act as temperature-sensitive resistors
within the bridge. The heating current generates a voltage signal, proportional to the mass air flow, as a precision
resistor. This is the signal transmitted to the ECU. To prevent "drift" that could result from contaminant deposits on
the platinum wire, the wire is heated up to a "burn off" temperature for one second each time the engine is
switched off. This process vaporizes and/or splits off the deposits and cleans the wire.
HOT-FILM AIR-MASS METER
This is the current MAF design in use on the Volkswagen TDI engines. The heated element of the hot-film air-mass
meter is a platinum film resistor (heater). It is located on a ceramic plate together with the other elements in the
bridge circuit. The temperature of the heater is monitored by a temperature-sensitive resistor (flow sensor) also
included in the bridge. The separation of the heater and flow sensor facilitates the design of the control circuitry.
Saw cuts in the ceramic are employed to ensure thermal decoupling between the heating sensor and the intake-air
temperature sensor. The complete control circuitry is located on a single layer. The voltage at the heater provides
the index for the mass air flow. The hot-film air-mass meter's electronic circuitry then converts the voltage to a
level suitable for processing in the ECU. This device does not need a burn-off
procedure to maintain it measuring precision over an extended period of time, as does the hot-wire air-mass sensor.
In recognition of the fact that deposits collect on the sensor element's leading edge, the essential thermal-transfer
elements are located downstream on the ceramic layer. The sensor element is also specifically designed to ensure
that deposits will not influence the flow pattern around the sensor.
The VW TDI ECU receives the input from the hot-film air mass sensor (MAF) and along with the engine speed
sensor's signal (ESS or rpms) calculates a load signal corresponding to the air mass inducted into the engine during
each stroke of the piston based or its internal programmed fuel maps. This load signal serves as the basis for
calculations of injection quantity, timing, and duration by the BOSCH VP VE 37 rotary distributor injection pump.
These signals from the MAF hot-film air mass sensor and the engine speed sensor are further modified in
accordance with the coolant temperature sensor signal, fuel temperature sensor signal, manifold air pressure signal,
and the intake air temperature signal. Although the primary input circuitry controlling the fuel delivery, timing, and
duration pulse to the fuel pump is derived from the MAF and ESS, the other sensors mentioned are
also monitored to fine tune the fuel output signals from the ECU in order to achieve the highest levels of
performance, economy, and emissions.
Please note from this discussion, that the VW TDI hot-film air mass sensor does not need to be cleaned each
time of use as was the previous version of hot-wire air mass sensor. This means that a K&N type oiled cotton
gauze air filter should not affect the operation of the hot-film air mass sensor as was previously speculated in
another post about this suspected problem.
