Old January 14th, 2020, 06:54   #16
turbobrick240
turbobrick240's Avatar
I bet very few dealerships are buying tdi spec. oil in bulk these days.
turbobrick240 is online now   Reply With Quote
Old January 14th, 2020, 16:25   #17
JesseTDI
Agreed, like I said there is no guarantee what you are getting (aside from actually watching the tech fill your car) when you go.
JesseTDI is offline   Reply With Quote
Old January 14th, 2020, 16:37   #18
bizzle
bizzle's Avatar
I suppose one could argue that there's no way to know if the techs are replacing *any* oil, but to the extent they use bulk oil it's probably 504/507 to include any car that would be serviced instead of keeping all kinds of bulk around. More likely, they service so few diesels they just grab quarts off the shelf. That's what the dealership told me they do when I brought mine in for other work but they could have been lying, which brings us back to how does anyone know anyone does anything they say...
bizzle is offline   Reply With Quote
Old January 15th, 2020, 19:04   #19
[486]
TDI(s): 02 golf ALH
502.00?
the cheap 5w40 we get from lube-tech in bulk has that spec on the label
ETA: and every tsi I've seen calls for it too, nowadays
[486] is online now   Reply With Quote
Old January 15th, 2020, 19:50   #20
turbobrick240
Originally Posted by [486] View Post
502.00?
Sounds more like an all purpose spec.. But yeah, the handful of VE tdi owners still doing oil services at the dealership may be getting decent bulk oil. They are pretty tough though. I'm sure more than few have made high miles on cheap 10w30.
Old January 16th, 2020, 06:35   #21
SilverGhost
SilverGhost's Avatar
Last dealership I worked for bought 507 in bulk - 55 gallon drums.
I have worked a few places where they insisted on 5k oil changes because of the Passat 1.8T fiasco, and to some extent the older TSI and FSI when they got higher mileage. After seeing the oil in high mileage GTIs I agree on some cars over 100k getting 5k oil changes.
But I fight and argue (and include training on PD cam wear) that anything less than 10k on a TDI is a waste and actually can hurt the engine.
Most recent argument is lube tech turned service adviser that insists on new tires on front, regardless of tread depth on rear. Google where new tires go - tire rack and Michelin.
Jason
VW and ASE Master Mechanic. Means nothing without the 15+years working at VW. Also know my way around an aircooled 34 pict 3 or Bosch D-jet.
Old January 16th, 2020, 15:24   #22
turbobrick240
Buying oil in bulk isn't quite the same thing as buying bulk oil. Bulk oil gets delivered by a tanker truck.
Old January 17th, 2020, 06:25   #23
SilverGhost
Tanker truck pulls up, pumps 110 gallons into bulk tank and drops 2 55 gallon drums off. In both cases techs get a jug and parts guy fills it for them.
I think once we get past a container we can pick up and pour into the car it becomes semantics over what is considered bulk.
Jason
Old January 17th, 2020, 07:21   #24
[486]
TDI(s): 02 golf ALH
I remember overhearing the sales guy talking about how the cheapest oil that we stock is a synth blend now, because the most recent api grade is so stringent.
Old January 25th, 2020, 20:07   #25
asgoodasdead
the dip****s at the drive through oil change place by my house are always like "wow your oil is very black we sell a cleaner we can run through it you know you should be changing it every 3k miles blah blah" and I'm just like ''its a diesel. its black after 1 mile"
then they show me the dipstick to show that its full after replacing the oil and having me run the engine for a bit and its just as black as the old oil
Sent from my Titan using Tapatalk
asgoodasdead is offline   Reply With Quote
Why is 5000 miles too soon to change oil? TCsWhiteKnight TDI 101 38 April 23rd, 2014 15:42
5000 miles - 1st oil change booksgamesvideos TDI 101 4 November 6th, 2012 08:05
RotellaT @ 5000 miles, keep or change? lojasmo Fuels & Lubricants 11 July 18th, 2003 21:22
How close to 5000 miles for first oil change? arrowman Fuels & Lubricants 3 June 30th, 2003 10:16
First oil change at 1000 or 5000 miles? hotzuk VW MKIV-A4 TDIs (VE and PD) 7 August 25th, 2002 19:13
Page generated in 0.13842 seconds with 12 queries
[Output: 100.86 Kb. compressed to 86.31 Kb. by saving 14.55 Kb. (14.43%)]
