JFettig
I'd be more than happy help log and give advice in Iowa
Did you notice any improvement in your shifter feel? I thought the BFI mounts tightened things up nicely. Especially now that it is getting colder in our part of the country, things seem pretty ridged...but maybe you were expecting more?I'm running all three BFI Stage 1 mounts and it still feels like there's a big rubber band holding the engine in place. Particularly on engine transition from powered to overrun, it feels like there's a huge amount of backlash/windup in the drivetrain
Vibration is still there (unchanged), and comes and goes when it feels like it...
The top half of the big end of the rod bearings are showing signs of wear - The bearings are "tired"
#1
fub's look pretty normal in my experience for rod bearingsWhat oil are you using? The bearings in my 300K miles ALH didn't look nearly as bad and that engine was run on the wrong oil most of its life. Also, how are the crank journals? Something isn't right.
You would never expect issues on the lower half bearings unless running at sustained extremely high RPMs, where the mass forces of the reciprocating group dominate.Crank is perfect and so is the lower half of the rod bearing along with the mains. I'm using a full synthetic 5w40 diesel oil from champion. I'll get specs on it at the shop this morning.
for "cracked cap" rods like in the CR motorsI'm not sure if the darkside bearings have the lock tab or not.Rosten offers the bearing with or without the lock tab,
I can tell you that I had the EOT up to operating temperature and didn't like the pressure that I saw at any given engine rpm.I had determined that it was simply overkill.Hmm - hopefully the rod bearings I have coming from Darkside have the lock tab.
Oil pressure ran right around 20 psi when warm (160F) at highway speeds (1600-1900 RPM) with a 5w40 oil and stock ALH pump/gear. I do have a bypass filter which steels some oil and may reduce pressures a bit when warm, but I've not taken the time to block/unbock the bypass to check it's effects on oil pressure.
Andy - can you explain why you thought the oil pressure was too high with the BHW Oil Pump Sprocket?
155 bar for a stock ALH. The R-TDI engine from 1997 had PCP of 185 bar to produce 190 HP but peak torque was "only" 350 Nm, and this at 3500 RPM.I can feel this becoming a deep hole What is a generally acceptable value?
