Metal Slug
Hi all,
So first off, I'm not asking for torque specs; I've got all those, but I've read here and there that a lot of the suspension components need to be torqued while loaded (ie. on the ground or with a jack applying pressure to suspension), but I don't see anything about this in the ebahn version of Bentley and a lot of shop videos torque everything while on the lift. I'm just trying to figure out which components need to be torqued while loaded, so I'm making a list with blank spaces that hopefully people can fill in on what can be done while up in the air and what needs to be torqued on the ground or if someone can point me in the right direction if this has been posted in the past. Thanks
Front
Top nut on front strut assembly to chassis:
Pinch bolt:
LCA (control arm) bolts:
Ball joint to knuckle: (I assume this one should be torqued before even installing axle since there is no room to even counter hold the stud after).
Ball joint to LCA:
Sway bar bushing bolts:
Sway bar link bolts:
Tie rod nut:
Inner CV joint Triple square bolts:
12 point axle nut:
REAR
Top shock bolts:
Bottom shock bolt:
Large, rear bushing bolts:
Front
Pinch bolt:
Ball joint to LCA:
Tie rod nut:
12 point axle nut:
REAR
Top shock bolts:
Bottom shock bolt:
