Speedster
Having been struck twice with catastrophic turbo failure while on road trips, the first 500 miles from home and the second 50 miles, I have wondered how to prevent the reoccurrence of a third such failure.
The first failure was at 78K miles and due to "high altitude surge." The bearing was still near perfect, but the shaft parted. The second failure at 138K was due to bearing failure on the exhaust side. Both times, a large quantity of crankcase oil flowed into the exhaust. I replaced both turbos myself, and wrote the Turbo How To in Wingnuts fine collection after the first failure.
What I am going to do from here on out is to examine the turbo shaft for movement on each oil change. If I detect any movement, I will rebuild the turbo with a new bearing and related parts.
On the second breakdown due to failure of the bearing, I had noticed some oil usage a couple of weeks prior to the failure. This was a red flag that something was wrong, I now realize. If I ever notice a sudden oil drop, I am again going to check the turbo shaft for movement, as well as the bottom of the intercooler for oil.
My thoughts are that turbo shaft bearing failure is not a sudden occurrence, and some periodic diligence in checking the shaft for movement should prevent breakdowns and the related expense. There is a Garrett VNT15 rebuild kit from Japan being sold on eBay for about $80.00. This is cheap compared with the costs of breakdown and a new turbo. Does anyone have any experience with this kit?
Can any of you experienced turbo mechanics out there add any other periodic checks to make for bearing failure, or telltale signs of impeding turbo bearing failure?
With these cars, I think that some sort of turbo check procedure is probably mandatory to keep from getting broken down a long way from home.
Regards,
Regards,
