'lectricjeff
Hi,
I am pretty new to the forums and a first time owner of a TDI. I have a 2003 Jetta TDI. I took a trip to West Virginia this past weekend and on the way home the car went into limp mode and had an overboost code (see below).
I have been noticing a seeming intermittent lack of power since I bought it and am leaning toward a gummed up turbo. The previous owner told me he shifted around 2500 RPM and from reading this forum it seems babying the car is bad for clogging up the vane mechanism.
I have a Ross Tech cable and VCDS on my laptop, I just don't have all the knowledge or tools to properly diagnose this and I would rather not be a parts changer.
I am in the Exton PA area if any gurus would be able to help me out. I have no problem buying whatever parts are needed and compensating for time with money or a mutually agreed upon payment.
Sunday,19,May,2019,18:24:42:11195
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: 3VWSP69M13M058940 License Plate: KXY8017
Mileage: 379975 Repair Order:
Address 01: Engine Labels: 038-906-012-AGR.clb
Control Module Part Number: 038 906 012 GN
Component and/or Version: 1,9l R4 EDC G040SG 4308
Software Coding: 00002
Work Shop Code: WSC 00066
Additional Info: 3VWSP69M13M058940 VWZ7Z0B5774561
VCID: 629DAB06ED5D0AA7E89-4B3C
1 Fault Found:
16618 - Boost Pressure Regulation
P0234 - 35-00 - Limit Exceeded (Overboost Condition)
Readiness: 0 0 0 0 0
www.Ross-Tech.com
1 Fault Found:
