Don't be tempted to tighten the hold down fork/clamp, they can break.
They should only be around 18'#s. Remove the fuel line at the top and loosen same at the IP.
Clean as best you can around the seat, and see
if the injector is loose. My bet is it wasn't seated properly.
If it pulls out you want to carefully clean and examine the copper crush
washer. You may need a pick as they sometimes don't come out with the injector.
Replace and give it a good thump, a large brass drift is ideal,
don't damage the threads of the top of the injector. You can anneal
the washer by heating to red hot and quenching in water.
You want nice clean surfaces for the copper to conform to.
Then retorque the hold down clamp, it is meant to only hold it in place
once you've reset the injector into the soft washer. Be carefull re-attaching
the steel fuel line so that it's unstressed, then retighten at the IP.
It's doubtful the injector body itself is leaking, though possible.
