So, the turbo side oil feed fitting came out easily with 17 mm socket. The fitting going in is a M10 x 1.0 with a 14mm hex for the wrench/socket.
The banjo fitting and bolt replacement is 12-1.5.
The compression fitting at the turbo end was slightly elongated the opening the oil flows through that is, and had a low spot where it had worn away, so that’s where the leak came from. The guru shop in Colorado Springs that installed it either left it loose or tight and it ended up this way. So the car will be starting on it’s third turbo oil feed at 293k and this one will finally
Be right and installed right and not a failure prone pos to begin with.
I am using 3' of 4AN hose. I have already mocked it up to the former banjo fitting end under the oil filter. Its length is fine, could be longer or shorter and still be fine.
However, that M10x1.0 fitting using a 2" length of rubber hose off the end of it to be able to control it, got wedged down immediately to the rear of the car from where the oil fitting goes, down in those brackets and what not. It is impossible or nearly impossible to get it up and out for another attempt with one arm and whatever tools I can manipulate it with. It sometimes moves about 1mm in any direction and other times as much as 3-5 but cant get it up and out. I have tried to recover it for about 1.5 hours and decided to take a break.... truly a laugh or cry scenario pretty typical with this thing.
I am an average mechanic for my experience. I have pulled engines, did an auto to manual trans swap once on a race car I built etc. Swapped rear ends on my own etc. etc. I am more a theory guy whether automotive or aeronautics etc.
I like the way this car drives for what it is for the most part. I like the efficiency and the general big picture durability, but it is one of the most piss money away frustrating to work on cars I would ever want, and I barely want it about half the time due to some of this nonsense. It's like it's conspiring against me. To get the hard line out I had pulled a coolant hose that descends straight down out of that manifold at the back of the engine. As some coolant was surging out I noticed there's about a 3/4" hole in the top of the bell housing that it started pouring down into for a bit till I caught it. should there be a plug of some sort in that hole? My guess is yes... now i am guessing there's a good chance the clutch will want to slip to one degree or another when I go to drive it after the rest of this is complete.
There is a good chance I will leave that fitting sitting wedged in right where it is, go get another and be even more careful than I already was to get the fitting in the hole and finish the rest of the job which is only 5 min worth....literally. This is a 10-15 min job total that will end up at 2-3 hours considering all the hassle and trip to go get another fitting if I have to.
The place I am using is a place I was last at in the late 90s early 2000s while working on one race car or another. I am glad I went back. I will likely be back and likely recommend them to reproduce this line for those of you who want or need to do the swap and just about anything else plumbing related for your TDI or whatever. I have never done mail order with them but I will ask about it probably tomorrow see if they'd be willing. It was expensive but much less expensive than I paid for another piece and same quality or higher I am sure.
Anyway the more frustrating than it needs to be saga continues... I will post up more later preferably at completion.
