Old May 11th, 2019, 10:41   #1
sloinker
sloinker's Avatar
Default displays and how to get them.
Different displays and how to get them? I was looking at my selectable display a while back and was seeing oil temperature as part of the driving data. It is now gone and replaced by climate information, fan settings, mirror heaters etc. I didn't set out to change this. It somehow changed itself or I inadvertently did it myself. Is there a guide somewhere that lets me program what is displayed in all the menu folders? I'm not seeing it in the owners manual.
sloinker is offline   Reply With Quote
Old May 22nd, 2019, 10:44   #2
sloinker
sloinker's Avatar
btt
still wondering why the oil temp display has been replaced by the HVAC display.
Old May 22nd, 2019, 11:46   #3
Chris Bell
Can't explain that change, but you can add items to the selectable menu list using VCDS.
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Chris Bell is offline   Reply With Quote
Old May 22nd, 2019, 14:26   #4
KERMA
KERMA's Avatar
I think you are talking about Polar FIS
HP is for show, TQ is for go.
celebrating http://www.kermatdi.com since 2002
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
Old May 22nd, 2019, 15:45   #5
rpm-inc
I have vcds but havent used it in quite a while. Any write ups for that?
rpm-inc is offline   Reply With Quote
Old May 22nd, 2019, 16:20   #6
Chris Bell
Select Control Module/Module 17-Instruments/Coding/Long Coding Helper/Byte 10/Bit 1 - Oil temp Display - check.
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Old May 22nd, 2019, 16:43   #7
rpm-inc
Thanks! Already have oil temp. I will play with it.
Old May 22nd, 2019, 17:59   #8
sloinker
sloinker's Avatar
Probably should get me a VCDS, two '15 tdi's and a '16 Tiguan probably justifies the cost. Polar FIS? Just the standard display that you can show the compass, speed etc.....
Old May 24th, 2019, 09:37   #9
AGOODHI
TDI(s): MKVII GSW
aren't these options configurable via the radio/nav/console... whatever it's called???
2015 GSW SE (new 60 miles) | Black | DSG | Bi-Xenon | Pano | Fender | Madico Onyx Tint | Ceramic Pro | deAutoKey LEDs | H&R Sport Springs
AGOODHI is offline   Reply With Quote
Old May 24th, 2019, 13:13   #10
Chris Bell
For the options factory-installed on the menu, yes, but you can add configurable options to the menu via VCDS.
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Old May 24th, 2019, 15:26   #11
AGOODHI
TDI(s): MKVII GSW
but i think OP is looking for oil temp, and where it went. i see oil temp in my display, and haven't done any vcds on those options.
Old May 24th, 2019, 17:32   #12
bigb
I have oil temp as well, it's in the driving data. Once you are in the driving data screen you toggle to whatever you want. One set of arrows gets you to driving data then the other set selects which data you see. It is confusing at first because you have four sets of arrows, two sets on each side of the steering wheel. Not sure if this helps the OP or if they already know this and it just is not there anymore.
Brian...
bigb is offline   Reply With Quote
Old May 24th, 2019, 17:49   #13
Chris Bell
Yes, you are quite right. I added an item to the Car/Setup/Multifunction Display menu with VCDS and couldn't remember if it was Oil Temp or something else. I just checked and it was "Refuel Quantity", which turns out to be a totally useless value the way it is displayed.
What will be interesting for the OP is to see if the "Oil Temp" option has disappeared from the Car/Setup/Multifunction Display menu or if it was still there but somehow unchecked without the OP's input. Even more interesting will be to see if some sort of HVAC display option has appeared in the menu!
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Old May 25th, 2019, 15:00   #14
sloinker
sloinker's Avatar
This is what happened. I don't have the oil temp display on the driving data as I once had. I now have HVAC. I have spent some time trying to see If I can make any changes with what is available to me via the menu's bot it just isn't there. I must have somehow changed the original selection but I can't replicate it now to go back. HVAC....who cares?
Old June 5th, 2019, 09:50   #15
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
Other than oil temperature, what other information can you enable with VCDS?
Anything useful?
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
fuses and warning displays DaveBBoxster TDI 101 2 December 12th, 2017 04:48
Displays do not turn off txv5181 TDI 101 6 October 30th, 2013 21:02
MFD mileage displays flylow2 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 March 29th, 2010 11:52
Hidden displays on MFD? dr.zed VW MKV-A5 Golf/Jettas 5 February 21st, 2009 05:02
Digital displays gone?? Kat02 TDI 101 14 August 17th, 2007 13:42
Page generated in 0.21064 seconds with 11 queries
[Output: 127.14 Kb. compressed to 105.49 Kb. by saving 21.65 Kb. (17.03%)]
