Old May 13th, 2019, 19:59   #16
Chiroman
Originally Posted by bizzle View Post
You need to determine which map version you have installed. Regardless of whether any of these are compatible with your car, the only one that will work without going to a dealership (or paying a 3rd party) and activating it is by replacing it with the exact version that was lost.
If I pull the SD card out with the nav data, then go into system settings, the info for navigation database is blank. So if the OP's car came without a nav SD card, I don't think there is a way to determine which map version was installed previously. But it makes sense that this would be the only version that will work without being activated.
Chiroman is offline   Reply With Quote
Old May 13th, 2019, 21:53   #17
Chiroman
Originally Posted by TDIintheSkys View Post
Interesting, so do you think the "M" version with the more updated v6 would work on my 2015 TDI SEL (it appears you may have the same vehicle in Canada, correct?)??
And if it does, is the full item #5G9919866M ?
Just to clarify: The ebay link posted for the "S" version (part# 5G0919866S) is for North America, but seems old at V3. Perhaps someone that has this part# can confirm the map date. Also, the ebay link for the "Q" version (part# 5G0919866Q) is for Europe.
The part number that your dealer gave you (ie. 5G9919866Q) is probably the most recent version with 2018 maps. I have the 5G9919866M maps which are 2016/17. Both are for North America, and would work on your 2015 TDI SEL, as that's exactly what I have (excpept in Canada it's called a Highline instead of SEL). The other part# that your dealer gave you (5G0919866S) just doesn't seem right. Dealers are almost next to clueless when it comes to anything relating to updating nav maps. But as Bizzle mentioned, if you don't replace with exactly the same as what you had, then you will likely need activation.
SD card music mystery '15 GSW Oldboatdriver VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 16 April 10th, 2019 21:55
2016 TDI SEL GSW 6mt mxtdiguy VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 25 April 12th, 2018 07:38
New (to me) TDI - 2015 GSW SEL (a Buyback) ritsco VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 14 September 21st, 2017 17:34
Glad you bought a '15 Golf TDI SEL vs. '14 w/nav and sun? Fsonicsmith VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 16 January 27th, 2015 13:20
Only problem w/ 15 Golf TDI SEL -The Nav pillboxhat VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 14 August 26th, 2014 19:11
Page generated in 0.14219 seconds with 11 queries
[Output: 55.88 Kb. compressed to 51.68 Kb. by saving 4.20 Kb. (7.51%)]
