Old May 9th, 2019, 09:26   #1
BIO-PWR
Question "Keyless Start Faulty" warning, driving me nuts!
Hello - Have a 2015 Sportwagen S 6MT with just under 30k miles. For the past month or so I have been receiving a "Keyless Start Faulty" warning (with a lovely "ding!") on the dash, and a yellow exclamation point warning light. The warning re-occurs every time I open / close the door (driver's), every time I open a window (any), when I come to a stop, when I set off and when I lock/unlock the doors with the fob or the driver door panel. Luckily the incessant beeping stops once I get on the highway / am driving continuously.
The car runs and drives perfectly and I would be OK living without the keyless door opening - I have no problem pushing a button on the fob / keeping the car unlocked. I just want the dinging and warning message to go away!
I have a RossTech cable and it tells me that the fault is originating from the Driver door antenna. I was able to disable the KESSY system but not the system that warns me that there is a fault with the KESSY system. For that I need a security code that I cannot find.
So my questions are thus: Has anyone had this problem? If so, what did you do about it? Is it possible to simply disable the warnings using VCDS?
I'm told by my dealer that I likely need to replace the entire door handle (ie, special tools and paintwork required). The car is Malone#2 (so fun!) and I'm wary of factory diagnostic equipment. I may flash back to stock and have the dealer take care of this under warranty unless you kind folks have a better solution for me! I would rather save increasing my re-flash count for any potential future serious problems, not this little luxury feature problem.
-E
2015 Silk Blue GSW S _ 6MT _ Malone Stg2 _ Atlas Skidplate _ FrostHeater _ 2" Ecohitch _ Sparco Terras _ 215-55r16 Michelin AS3+ _ Linear throttle _ Clutch delay removed
'01 Golf _ 402k _ 11mm pump _ VNT17 _ DLC1019 _ vwmikeL tuned _ PD Lift Pump _ FMIC _ 3 Bar MAP _ PD150 Intake _ SBC Endurance Clutch _ 2.5" WB DP with full SS exhaust _ Bilstein HD _ .658 fifth
BIO-PWR is offline   Reply With Quote
Old May 9th, 2019, 09:32   #2
kdawg89
Do you have some kind of extended warranty? I donít think it would be covered under the factory warranty, if they will fix it under warranty I would let them. I wouldnít bother flashing back to stock. If they check it wonít matter what the current tune is in my opinion. VW servers will check the flash count and if it doesnít match it will get TD1 flag. In my opinion they have no reason to mess with all of that for your issue. And even if they do check I donít think VW would deny that kind of claim based on tunes.
15 Golf TDI SEL DSG, Kerma TDI Tunes
Sold:06 Jetta, Darkside GTB1749V turbo, stage 4 malone tuning, 3 bar map, EGR delete, ASV deleted, buzzken catless downpipe, IDParts billet cam
kdawg89 is offline   Reply With Quote
Old May 9th, 2019, 10:31   #3
Lightflyer1
Lightflyer1's Avatar
The number of flashes isn't the thing. It is if the count matches up with what they have on record. Even being off by only one is enough for the TD1 flag, from my reading. It probably would go "in your record" and could be used against you later, if not this time.
Old May 10th, 2019, 06:35   #4
BIO-PWR
Ok, fair enough - I knew I signed up for potential warranty issues when I flashed it. Gotta pay to play - can't deny that I love the extra power and torque without losing fuel economy.
Warranty / dealer issues aside, any suggestions for how to diagnose and fix this problem? Many others have pointed to the KESSY antenna under the rear bumper, but my VCDS scan tells me it's an antenna in the driver door. Is this antenna truly a part of the door handle?
Side note: I was planning on installing dynamat sound insulation to the front doors so I may have an answer to that once I remove the door panels.
Old May 10th, 2019, 07:39   #5
740GLE
Are you able to pull off the door card and poke around?
Do some searches on mk7 specific forums (this places is kinda stale with MK7/MBQ specific tricks and DIYs) you won't be the first person to pull the cards off to root around.
Old May 10th, 2019, 09:47   #6
BIO-PWR
Pulling the door panel is on the list for this weekend. Need to get the other project running so I can get the garage space first... Good tip on the MK7 threads (vortex, golfmk7.com, etc...) have a lot of good stuff on this. TDIclub has been awesome for teaching me about my '01 ALH -I really appreciate the community's effort to put together great DIYs. Sadly there aren't many tdi MK7s out there and they are still pretty new (ie, not broken yet). Lucky our tdi suppliers have been on the ball stocking MK7 stuff (IDparts!).
Keyless Start Faulty TarwheelTDI TDI 101 3 October 1st, 2015 19:18
car won't start, warning light says "low oil pressure" sweatmachine TDI 101 14 September 20th, 2008 12:46
Idea for you "VW is soo unreliable" nuts bhtooefr TDI Conversions 9 March 3rd, 2007 21:12
"Mileage" vs. "MPG" vs. "Mile range" vs. "Miles per tank" boyelectric TDI Fuel Economy 33 August 19th, 2002 06:06
15" stock steel wheel lug nuts fit on 17" vw wheels? days-like-this Upgrades (non TDI Engine related) 8 July 13th, 2002 15:51
Page generated in 0.14737 seconds with 11 queries
[Output: 77.01 Kb. compressed to 67.70 Kb. by saving 9.31 Kb. (12.09%)]
