Old May 4th, 2019, 15:33   #1
acsomay
Question Kessy/Keyless entry key programming/pairing
Hi,
I have two 2015 Golf SELs. Both of they have keyless entry (KESSY) and push to start. The first one is a hatchback that we purchased brand new with 2 sets of keys. The second one is a SportWagen that we bought used last year and with only one key
I ordered a new key from the dealer which arrived, but I was wondering if I can get all four keys programmed by the dealer to open both cars, so I would be able to walk up to either of the two cars and open the door. Usually what happens is that I grab the wrong key by accident, or plan to go with my car, but I need something out of my wife's car, but don't have her key on me. (living in a rental building on the 3rd floor with one car on the streed, the other in the alley, so it's not fun when you don't have the right key on you :P )
I asked the dealer two separate times, but they said it is not possible. But I wouldn't fully trust what they are saying ...
I don't know too much about cars, but I'm in it, and the way the dealer explained it and what I was able to find about this topic here and around the interwebs is the following:
The keys need to be programmed/paired to the car at the dealer, and only the dealer can do this. All keys previously working with the car but not present at the programming will stop working with the car.
I', wondering if this pairing will break the previous pairing of the key with another vehicle, because if not, then one key could be paired with two (or more) cars allowing me to do what I'm trying to do.
In my mind during the pairing/programming of the key they are "telling" the car (car1), that these are the keys you are OK to respond and allow yourself to get opened/started with. It should not stop my other car (car2) to recognize and react/open to the keys it was already programmed/paired with in the factory. As car2 is not "online" it can't know that the keys were paired with another car, unless there are things in the key that are changing during the pairing.
So, does anyone know if this is possible? Paring 2 cars to the same 4 sets of keys?
Thanks!
acsomay is offline   Reply With Quote
Old May 4th, 2019, 16:14   #2
ProfBrown
Fuel Economy: In the sig
Default Kessy/Keyless entry key programming/pairing
I have been known to be wrong before, but I donít think this is possible. The remotes are set to a certain frequency to activate the KEESY system in one specific car, with each car having its own frequency. I donít believe the keys are able to transmit two frequencies at the same time, for obvious hacking reasons likely. If they could, then I could make my key open your car door if I had the computer know how.
2015 GSW TDI SE DSG
DON'T TRACK THIS ANYMORE
ProfBrown is offline   Reply With Quote
Old May 4th, 2019, 16:30   #3
Nuje
Cheap solution (because we faced the same thing with our two Mk7s):
https://www.amazon.com/Keyless-Prote...dihnscelwas-20
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, Adaptive Cruise retrofit
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is online now   Reply With Quote
Old May 8th, 2019, 23:22   #4
Spacewalker
TDI(s): 2.0 CR
New key from Dealer order via VIN - must be learn via Dealer or with proper tool (like VVDi2)
if you buy brand new Key (virgin) you can only learn it to car via tool like VVDi2
Immo and Remote (with kessy system) is learn automatic
I retrofit kessy to my car few years ago and did all by myself via VVDI
HOT HOT Cruise Control via MFSW HOT HOT
https://www.youtube.com/watch?v=JQ8c...ature=youtu.be
Spacewalker is offline   Reply With Quote
Old May 14th, 2019, 08:26   #5
acsomay
So do you think it is possible for a key to open two cars at the same time? If it is learned to both cars?
Old May 14th, 2019, 13:57   #6
Nuje
I'm gonna say "not a chance". Pretty sure each key has one and only one "memory pairing slot".
Old May 23rd, 2019, 08:58   #7
Spacewalker
TDI(s): 2.0 CR
hmm.... remote - maybe yes
Kessy key - if you transfer immo data (and both have this same)
so 2nd car is like a clone
also I think yes
Keyless entry programming problems Shikaroka VW MKIV-A4 TDIs (VE and PD) 13 December 6th, 2013 13:19
2010 golf keyless entry programming question scottp TDI 101 0 August 7th, 2013 07:09
Programing Key, not Keyless entry... blu_jet_92 OBD Scanners 2 June 5th, 2011 22:35
Keyless entry programming ????'s geez VW MKIII-A3/B4 TDIs 4 May 7th, 2007 20:46
Programming keyless entry STIFFLER VW MKIV-A4 TDIs (VE and PD) 2 August 7th, 2003 13:06
© 1996 - 2020, All Rights Reserved
Page generated in 0.13673 seconds with 11 queries
[Output: 83.09 Kb. compressed to 72.59 Kb. by saving 10.50 Kb. (12.63%)]
