Old April 23rd, 2019, 07:58   #16
dobeonguard
dobeonguard's Avatar
TDI(s): 98 Jetta TDi
Tow ratings are based largely on emissions.... They can't certify the vehicle for towing if it will exceed the emissions requirements during towing.
Tork Lift Centra have nice hitches.
https://torkliftcentral.com/trailer-...-golf-ecohitch
dobeonguard is offline   Reply With Quote
Old May 1st, 2019, 05:58   #17
petee_c
Fuel Economy: 5.6ish L /100km golf.... just under 10L/100km q7
anyone getting clunking with their curt hitch receiver.... I wonder if it's the muffler bouncing against the exhaust when going over bumps? I only notice it the 1st few minutes of the drive.
or maybe its the loose heat shield....
petee_c is offline   Reply With Quote
Old May 1st, 2019, 07:40   #18
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
I had the same issue on another car none VW.
2015 Golf SEL. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old May 1st, 2019, 09:28   #19
740GLE
Originally Posted by JM Popaleetus View Post
It’s clear you don’t understand how liability works.
It’s completely understandable why an installer wouldn’t want to install a hitch for boat towing on a small car that’s not rated for it in the USA. Even though the drivetrain is more than capable.
But by all means, continue to be an ass.
https://newsroom.vw.com/vehicles/goi...untry-concept/
omg look at all those liabilities VW is promoting
*See vehicle owner’s manual for details and limitations. Consult aftermarket manufacturer for accessory installation instructions and further information.
Old May 2nd, 2019, 01:30   #20
turbobrick240
turbobrick240's Avatar
If part of moving that pontoon boat 3 blocks involves a boat launch, I wouldn't recommend it. Ask a friend/relative/neighbor with a more suitable vehicle to help.
Old May 3rd, 2019, 05:03   #21
JM Popaleetus
JM Popaleetus's Avatar
That's a concept.
And you're still being dense around my entire point that an installer has every right to refuse a hitch on a car not rated for towing. Especially since we were talking about towing a boat, not a bike rack. IF an accident ever happened, lawyers could name the installer in a suit and insurance is likely to deny the claim.
2015 VW Golf TDI SEL (DSG, Lighting and Driver Assistance Packages, Tornado Red/Titan Black)
2007 GMC Sierra 2500HD Classic (Duramax LBZ, SLT, Extended Cab, Summit White/Ebony)
2013 VW Passat TDI SEL Premium] Buyback
2010 VW Jetta TDI RIP
JM Popaleetus is offline   Reply With Quote
Old May 3rd, 2019, 07:38   #22
dubStrom
dubStrom's Avatar
I got the ecohitch (2" version) for my '15 GSW. The hitch is extremely beefy. I only wish that the TorkLift design had steel square tubes extending into the Sportwagen frme tubes with bolts accessible in the wheel wells. At least on one side. The bolts that utilize threads in the car body's back steel panel are weak, and the additional bolts are not much either. AND that back steel panel is not nearly as good as the frame tubes in the chassis. But GROUND CLEARANCE is unbeatable if you choose the TorkLift, and the cross tube is hidden.
I installed a Curt 11072 on my 2010 JSW. It had a brace that utilized the right side frame tube. THERE IS MUCH more strength in that mounting strategy:
http://forums.tdiclub.com/showthread...ight=fish+wire
Lost my JSW to a reckless MB E350 sedan driver blowing a stoplight:
http://forums.tdiclub.com/showthread.php?t=472255
dubStrom is offline   Reply With Quote
Old May 3rd, 2019, 10:19   #23
JM Popaleetus
Originally Posted by dubStrom View Post
I got the ecohitch (2" version) for my '15 GSW. The hitch is extremely beefy. I only wish that the TorkLift design had steel square tubes extending into the Sportwagen frme tubes with bolts accessible in the wheel wells. At least on one side. The bolts that utilize threads in the back steel panel are weak, and the additional bolts are not much either. AND that back steel panel is not nearly as good as the frame tubes in the chassis. But GROUND CLEARANCE is unbeatable if you choose the TorkLift, and the cross tube is hidden.
Thought's on Draw-Tite's method then?
https://www.etrailer.com/Trailer-Hit...leID=201531032
Comparing the installation instructions, it uses the bumper mount, frame rails, and is all one unit. Plus you only need to remove the lower valance to install, versus the entire bumper.
Old May 3rd, 2019, 12:46   #24
Nuje
I don't remember all the details of installing this Curt model on my GSW, but I do remember thinking, "This is SOOOOO much better than what was on my Mk4 Golf", which bolted through the sheet metal on the driver side.
IIRC, this model replaces the bolts which hold the bumper on with slightly longer bolts, so if the hitch comes off, it's bringing the bumper itself with it.
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, DSG tune
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
Old May 3rd, 2019, 13:19   #25
PB_NB
PB_NB's Avatar
I had a bit of clunking when going over bumps. I took some thin nylon ~1/16" and secured it to the receiver, I had to test fit it a few times but once I got it snug, I tightened it all up and it has been great for a few years and counting.
Clunking could also mean that the hitch could be loose on the car. You should check it to make sure it is secure. I used loctite on the bolts to help keep them tight.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old May 14th, 2019, 03:26   #26
tdi_hatch
I was getting some pretty nasty clunking. It was the muffler knocking on the receiver.
I loosened up the hangers and adjusted the muffler to give more clearance. The holes are slotted, so there's some room to move it where you want.
I installed mine to tow a '95 seadoo xp - Pretty light ski, but it towed no problem.
tdi_hatch is offline   Reply With Quote
Old May 15th, 2019, 11:12   #27
petee_c
thx guys,
noise is still there... I think it may be the exhaust shield... I'll stick it up on the lift in a couple weeks and try to get it resolved, busy until then...
I don't notice it much after I get over 20mph.
Old May 27th, 2019, 07:02   #28
petee_c
clunk and noise finally gone...
-removed loose heat shield... Mine came to me without the fasteners, and all the holes that it would have needed are messed up (reamed out by being loose)
- buzz is gone.
Also loosened the hitch and the muffler mounts... Moved the hitch to the right as far as it could go (less than 1/8") Moved the exhaust mounts as far as they could go to the left (about 1/8")
- no more clunking or rattles when driving...
phew.
Trailer hitch install mcad64 Ontario 4 March 10th, 2012 12:21
2007 Golf hatchback: tow bar (hitch) install dieseloz TDI 101 9 July 15th, 2007 22:04
Trailer hitch for Golf - where to buy & install sportsguy Atlantic Canada 18 June 7th, 2006 17:33
Trailer Hitch Install Issues mikeyworks Upgrades (non TDI Engine related) 4 September 23rd, 2005 07:45
Trailer Hitch Install milehighassassin Upgrades (non TDI Engine related) 6 August 3rd, 2005 09:48
Page generated in 0.18474 seconds with 11 queries
[Output: 124.60 Kb. compressed to 105.12 Kb. by saving 19.48 Kb. (15.63%)]
