Old April 15th, 2019, 14:08   #1
autoguru21
Default Question for Golf/Golf Sportwagen Sel Trim Owners
How many fellow tdi members here have a Golf/Golf Sportwagen in Sel trim with the bi-xenon lighting package? I am curious to know if anyone has used vcds to change from nar region to ece coding, i have replacement warranty bi-xenon headlight assemblies.
Since the headlight assemblies were being replaced i had my vw dealer install new Osram Nightbreaker Laser D3S bulbs and i did extensive long coding changes to make
headlights have the nar region disabled and i recoded them to european ece lhd headlight specifications.
Between the new headlight assemblies and bulbs the lights seem to shine further ahead than they ever have since i bought the car two months ago, and now they seem throw a beam much wider than they used to with the original headlight assemblies and now the beam level sits higher than the headlights that were original to the car and throwing afs codes and having issues with the motors and leveling system as well as the trim rings fell off inside the headlight, i also disabled my cornering lights as i no longer need them as a feature because of the significant improvement.
I hardly even need to turn my foglights on anymore now, i'm interested in everyone else's opinion of my changes i have made, and how effective do your stock bi-xenon lights work at night because i have read quite a few complaints about the oem lighting package being a bit sub-par hence why i have done my modifications listed. I look forward to others opinions
autoguru21 is offline   Reply With Quote
Old April 15th, 2019, 14:20   #2
kdawg89
I donít know if I understand the question but I have OEM bi xenon lighting and am happy with it. I turned off NAR restrictions but I think that is different than the coding youíve done, I canít tell the difference between the restrictions off vs on.
15 Golf TDI SEL DSG, Kerma TDI Tunes
Sold:06 Jetta, Darkside GTB1749V turbo, stage 4 malone tuning, 3 bar map, EGR delete, ASV deleted, buzzken catless downpipe, IDParts billet cam
kdawg89 is offline   Reply With Quote
Old April 15th, 2019, 15:55   #3
Nuje
Same as kdawg89 here, too. OEM Lighting Package (BiXenons), and I've been very pleased with them. I've modded so that the fogs are always on (replaced with LEDs, mind you), and am never disappointed with light output, even in heavy rain.
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, DSG tune
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
Old April 15th, 2019, 16:34   #4
kdawg89
I did the same, fogs to beamtech leds and changed the running lights to the fogs rather than the main HID bulbs.
Old April 29th, 2019, 09:19   #5
Biggu
I also have OEM Bi-Xenon on my car and while I like the lighting output the cutoff line is so blurry and annoying that is has no color. I really want to get another set of OEM housings so I can try and modify it to have a clear cutoff.
Biggu is offline   Reply With Quote
Old April 29th, 2019, 12:30   #6
Chris Bell
Hella and I think Valeo have aftermarket versions of the OE Hella Bi-Xenons. Not sure of any design differences but price should be lower than OE versions.
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Chris Bell is offline   Reply With Quote
Old April 30th, 2019, 04:53   #7
CGR
Fuel Economy: 52.5/41/38.5
I turned off NAR restrictions and them adjusted them with a screwdriver to where I wanted them. The were too low from the factory, they pointed down in to the road right in front of the car.
2002 Golf 6SP DRW, 293K, RC3Euro, Sprint520's, Boost Guage, Boost Valve, DG Racepipe, Koni Yellow F, Koni Red R, VW GLI SS 2B/2W F, Stock Golf Springs R, Neuspeed 28mm RSB full stiff, Montreal II 16" wheels and Conti Extreme contact DWS 205-55-16. GLI Heated Sport Seats and interior.
2003 Chevy crew cab Duramax. 180k
CGR is offline   Reply With Quote
Old April 30th, 2019, 05:35   #8
sportwagen3
What's the color temperature of your fog lights?
sportwagen3 is offline   Reply With Quote
Old April 30th, 2019, 08:53   #9
Nuje
Color temp is about 5000K - very "white" white. Which yes, I know, isn't what fogs are supposed to be, but if / when I do want yellow fogs at some point in the future, the LEDs came with tinted (yellow - 3000K) sleeves.
I've seen other LEDs, too, where they cycle through different colours (two sets of LEDs on the "bulb").
Turn on - white.
Turn off, then on again - yellow.
Turn off, then on again - white and yellow.
(Or something to that effect)
(Edit: like these.)
Old May 17th, 2019, 12:25   #10
the_jeep_now
Fuel Economy: 41 MPG
Sorry a bit off topic but what does turning NAR restriction off really do? And what's the coding for it?
Sent from my SM-G892A using Tapatalk
the_jeep_now is offline   Reply With Quote
Old May 17th, 2019, 15:32   #11
autoguru21
What i've noticed from my own experience disabling the nar restriction and enabling ece coding has allowed my headlights to have more height above 30 mph, the headlights have more bend functionality in tight turns and corners, the light output is significantly better to where i rarely have to turn my fog lights on now, the coding is done through long coding via vcds
55-Xenon Range
Uncheck the box in coding that says North American Region Rules. This enabled me to have tourist mode capability (doesn't activate it) and takes off the restriction of 4 lights on at once.
The Xenon Range controller from NAR to RoW made an interesting change. The headlights will raise ever so slightly at faster speeds which, at least from what I remember, they do not in NAR format.
http://forums.vwvortex.com/showthrea...1#post87198755
WTB: 2015 Golf Sportwagen SEL (PA) marcoforehand TDI Cars for Sale/Wanted 2 January 30th, 2019 12:27
2015 golf sportwagen TDI SEL (Annapolis MD) MD2010jsw TDI Cars for Sale/Wanted 3 August 18th, 2018 16:20
2015 Golf SportWagen SEL TDI 36K Like New polka2017 TDI Cars for Sale/Wanted 4 May 3rd, 2018 19:10
Nutty's 2015 Golf Sportwagen SEL TDI 6MT Nutty 5.0 Golf TDI Picture Gallery 19 June 12th, 2015 15:12
Golf GL/GTI owners - outer trim question/problem GeWilli VW MKIV-A4 TDIs (VE and PD) 3 November 9th, 2001 07:06
Page generated in 0.15701 seconds with 11 queries
[Output: 103.29 Kb. compressed to 87.61 Kb. by saving 15.68 Kb. (15.18%)]
