Hi Everyone,
Another swap build going on but this one is a little different than most.
Some background on the vehicle.
1Z TDI from a 1996 Passat. The motor was overhauled and rebuilt.
The wire harness was cut down to a standalone harness by FAST FORWARD AUTOMOTIVE out of Canada. With 3bar map sensor and MK4 petal swap included.
Tuned with Malone Stage 4 Tuning
VNT 17 Garret Turbo
Bosio 520 Race Injectors
All to be installed into a 1989 Chevy S10. Bolted to a 2wd Toyota transmission. All is installed and it looks amazing sitting in the Chevy engine bay. Yesterday was the first start up. I had VAG COM plunged in to watch coolant temperature and engine RPM while it ran for the brake in period.
The engine turned over and fired in a matter of a few revolutions. After a quick scan of gauges to make sure I had oil pressure I noticed the RPMs were not going lower than 1200 and I had no throttle response as well as the Glow plug light was flashing.
So I turned the engine off.
Scanned for codes and found the following.
01268 Quantity Adjuster (N146)
18-00 - Upper Limit
00777 Accelerator Position Sensor (G79)
27-10 - Implausible Signal - Intermittent
On further scans with VAG COM I found that my Throttle position would read 7.5 with the paddle at rest and 100% when pressed to the floor.
I have been on the variety of forum sights the last 24 hours and have found minimal information that changed the situation I’m in.
Any help deciphering what’s going on would be great, Thanks.
-Dan
VNT 17 Garret Turbo
18-00 - Upper Limit
-Dan
