Old December 3rd, 2018, 05:04   #31
740GLE
So far I've had to add about 1 C to our '15 sitting with 28K on the clock. Knock on wood.
If someone were to DIY this, I imagine TB locking tools would be a minimum? Seeing other TB components aren't touched it'd be a bit easier?
Old December 3rd, 2018, 14:25   #32
adjat84th
adjat84th's Avatar
Crank lock and cam/pump pin are compatible from prior years CR motors. The procedure is nearly identical as well. No need to remove the belt completely, so no need to remove the motor mount and support the engine. I ended up having a small coolant leak rather than a leaking pump, though I suspect my pump was replaced in its first 15k miles before I owned the car.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old May 14th, 2019, 16:21   #33
Psybin
TDI(s): 2015 GSW
2015 GSW - 53k, losing coolant, dealer diagnosed leaking waterpump. They had to change the timing belt as well. Thankfully this happened before the magic 60k powertrain warranty bye-bye mark.
Psybin is offline   Reply With Quote
Old May 14th, 2019, 18:21   #34
adjat84th
adjat84th's Avatar
Did they replace tensioner and rollers? If not, I'd probably replace again at the normal interval. Nice you got a fresh pump on them though.
Sent from my Pixel 2 using Tapatalk
Old May 14th, 2019, 18:38   #35
Chris Bell
Could you check your invoice and report the part number of the water pump? I'm curious if they are showing a different p/n than the original that may indicate a non-variable pump replacing the original variable flow pump.
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Chris Bell is offline   Reply With Quote
Old May 15th, 2019, 08:27   #36
I haven't seen a new OE number for the non-variable pump. And any aftermarket manufacturer's number will be the non-variable, as I don't believe anyone in the aftermarket is making a variable pump for this application.
2002 Jetta wagon, 384K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 260K; 2011 335d, 60K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old May 15th, 2019, 08:34   #37
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
04L-121-011, then "E" suffix", then "L" suffix.
oilhammer
www.cardocautomotive.com
Water pump play is bad, right? Number6 VW MKIII-A3/B4 TDIs 13 August 13th, 2016 23:32
Water pump going bad? cactussam85 TDI 101 8 December 8th, 2015 11:18
bad water pump I think? compostbrain TDI 101 5 June 4th, 2008 05:42
What's the sound of a bad water pump? Medic1 TDI 101 3 March 1st, 2006 18:02
Overheating - Bad Water Pump scooter VW MKIV-A4 TDIs (VE and PD) 0 October 26th, 2005 11:09
Page generated in 0.13590 seconds with 11 queries
[Output: 83.63 Kb. compressed to 72.86 Kb. by saving 10.77 Kb. (12.87%)]
