Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old April 27th, 2016, 17:12   #46
vr6dubin0531
vr6dubin0531's Avatar
TDI(s): 05.5 Jetta
Fuel Economy: Tba
Pm sent
2005.5 brm
vr6dubin0531 is offline   Reply With Quote
Old October 17th, 2016, 12:06   #47
GotEuroCorrado
bumpers
ACS TDI SPECIFIC MAINTENANCE AND REPAIR IN HATBORO PA (267)317-8229
$650+/- ALH/BEW/BRM/BHW/CBEA/CJAA TIMING BELT KIT INSTALLED NEAR PHILADELPHIA !
used parts FS: http://tinyurl.com/zfdjgyh
smoking deals on TIMING BELT KITS: http://tinyurl.com/ov57jfl
GotEuroCorrado is offline   Reply With Quote
Old February 13th, 2017, 11:14   #48
GotEuroCorrado
still have a lot of stuff around!
Old March 18th, 2017, 14:41   #49
markieb
markieb's Avatar
Default egr cooler??
looking to replace my EGR Cooler in a 04' BEW
Ypu have? and How much? I live in florida 33954
markieb is offline   Reply With Quote
Old March 19th, 2017, 11:21   #50
Davidlinder
Fuel Economy: 45 mpg
I'm looking for a alh upper intercooler pipe, also may be in the market for a cpu mine is a 038 906 012 FD, I know that there are others that will work with this one. Do you have either one.
Sent from my iPad using Tapatalk
Davidlinder is offline   Reply With Quote
Old March 20th, 2017, 06:24   #51
GotEuroCorrado
no alh upper ic pipes, but i have several bew same as for ecu. only have 2 bd ones on it.
Old May 22nd, 2017, 18:30   #52
jjcsnlynn
jjcsnlynn's Avatar
Do you have the fuel lines from fuel filter and Injection Pump?
What about a timing belt cover?
02 Jetta TDI (5-Speed)
01 Jetta TDI w/03 engine (5-Spd Wife's)
96 Passat TDI (5-Speed Son's)
95 2500 Silverado Diesel 4x4
jjcsnlynn is offline   Reply With Quote
Old May 23rd, 2017, 05:54   #53
GotEuroCorrado
yes i do, you have pm
Old May 26th, 2017, 14:17   #54
4WDrift
4WDrift's Avatar
TDI(s): Jetta PD Mk4
I need an upper charge pipe for BEW.
(The large rubber hose with funky end connection clip that wears out.)
Let me know if you still have one please.
Diesel performance in mind, I went up to a monster 335d
Passed the ALH TDI to my kid.
4WDrift is offline   Reply With Quote
Old May 26th, 2017, 17:14   #55
Gluckmysock
ALH Glow plugs?
2002 Jetta TDI. VNT17 w/ Stage 4 Malone Tune. Custom gauges.
Gluckmysock is offline   Reply With Quote
Old May 29th, 2017, 20:40   #56
79TA7.6
79TA7.6's Avatar
Location: Live: Wilbur/Creston; Work: Moses Lake Washington
Alh turbo? Not sure if you keep getting stuff in or if it what you have listed is what you have.
2003 Jetta 5 Speed 301K miles. Malone stage 3. Titan 502 big hole injectors. VNT17 turbo. BuzzKen 2.5" down pipe. Ventectomy, EGR and cooler delete, Euro Switch, Home made custom HID.
79TA7.6 is offline   Reply With Quote
Old June 7th, 2017, 18:34   #57
633
Fuel Economy: 50 avg. 61 best 38 worst
Do you have an ALH injection pump bracket, also holds the tensioner and other pulleys?
633 is offline   Reply With Quote
Old June 7th, 2017, 19:58   #58
GotEuroCorrado
yes i think i have one left. ill check in the shop tomorrow.
Old June 13th, 2017, 21:07   #59
ProfessorGT
TDI(s): 01 Jetta TDI
Default 01M Automatic in good working order?
Looking for a good 01m. I know, don't laugh, but I was dumb enough to buy an 01 Jetta for my kid with an automatic, instead of insisting on getting a stick. Now I have issues with delayed/no reverse engagement and what feel like the torque converter clutch going in and out at lower speeds.
Any help is appreciated.
ProfessorGT is offline   Reply With Quote
Old June 14th, 2017, 06:31   #60
GotEuroCorrado
none, sorry
BEW, BRM, and ALH head gaskets oldpoopie TDI Power Enhancements 31 November 25th, 2017 19:07
TDI ALH BEW BRM Parts Precisiontuning Vendor & GroupBuy items for sale 0 December 14th, 2012 11:43
ALH vs. BEW vs. BRM sk8rdi16 TDI 101 36 August 24th, 2012 11:45
Wanted ALH/BRM/BEW Crank...99.5mm storx Private TDI Items for Sale/Wanted 1 February 14th, 2009 12:30
brm vs bew vs alh detoxed TDI 101 2 April 19th, 2007 19:52
Page generated in 0.10995 seconds with 11 queries
[Output: 125.60 Kb. compressed to 104.58 Kb. by saving 21.02 Kb. (16.73%)]
