ChrisMc
First off, the car just rolled 230K.
The first hot day of the year (a couple weeks ago), the coolant light comes on and sure enough, I'm low. I filled it with pentosin and distilled water. Two days later, the light came back on so I inspected it for leaks and didn't see anything. A buddy came over with a pressure tester and still no coolant leak found.
Late last year, I did the TB and replaced the water pump. Pulled the inspection cover and it doesn't seem wet near the water pump. At the same time I replaced the coolant flange and thermostat, which that doesn't seem to be leaking either. The heater core was replaced a year and a half ago. The car does not smell like coolant when running and does not overheat.
It's gotten to the point that every other day I'm adding fluid so the light doesn't come on. This is REALLY annoying.
The coolant expansion tank had a little residue on it and makes a hissing sound when cooling off (I think it's just the coolant moving around).
I plan on starting with replacing the tank and cap unless y'all have other input.
Thanks!
Thanks!
