Old May 14th, 2019, 17:06   #1
B-Line
TDI(s): 2001 Jetta
Default Need help with p0402 code
I have a 2001 Jetta TDI with 440,000 miles and I知 having issues figuring out my p0402 code. When it first appeared, I thought this was simply a dirty EGR so I removed it and cleaned it as well as the intake. They were pretty dirty but far from clogged. I reset the code and it returned after the second start and full warmup. I checked all vacuum lines and everything looked good and tight. All vacuum lines were replaced about 1 1/2 years ago. I致e been looking at the mass air flow sensor and I知 not sure how to interpret the results from live data on my scanner. At idle the readings 14.3 g/s and at full throttle it is 101.83 g/s peak and settled to 89.45 g/s. I知 thinking these are too low but I知 not really sure. I feel the car is slightly down on power but nothing extreme. I did unplug the mass air flow sensor and lost some more power but nothing drastic. I知 not sure where to go next. Any help or advice would be greatly appreciated.
B-Line is offline   Reply With Quote
Old May 14th, 2019, 17:12   #2
STDOUBT
STDOUBT's Avatar
What about the wiring? The plug to the ASV.
Is your EGR leaking air or oil? When the valve bushing fails it will leak.
Seems you've done everything except rule out the electrical.
From ross-tech:
  • Check/Clean Exhaust Gas Recirculation (EGR) System
  • Check/Replace Exhaust Gas Recirculation (EGR) Valve
  • Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve
2003 Jetta TDI 1.9L 5-speed
Malone Dynamic EGR
STDOUBT is offline   Reply With Quote
Old May 14th, 2019, 17:31   #3
B-Line
TDI(s): 2001 Jetta
I did not check the electrical connections. What should I be looking for? I did pull vacuum on he EGR valve and it functions normally. I’m not sure how to check for air leaks. Thanks for your help
Old May 14th, 2019, 19:43   #4
STDOUBT
STDOUBT's Avatar
OK, so if your EGR valve isn't spitting oily gunk onto your valve cover that's good. Undo the wire harness behind the AVS on the back of the EGR. Check for corrosion, check for chafed wires. Make sure the plug re-seats well.
Malone Dynamic EGR
Old May 15th, 2019, 03:57   #5
oilhammer's Avatar
Fuel Economy: fantastic
Not sure what wiring harness you are talking about, as there isn't one in that location on an ALH. The only wires back there are to the anti-shudder valve solenoid, and the breather heater, neither of which would cause this problem.
The EGR valve is a simple vacuum operated unit. Controlled by the vacuum regulator N18 valve on the firewall, the one closer to the center of the car.
EGR flow is monitored by the ECU watching the MAF value.
There is a Measuring Group you can watch the EGR operation, I forget which one but start at 001 and go up, it'll be in the first few.
Block 1 is RPM
Block 2 and 3 are actual vs. requested
Block 4 is EGR duty cycle
Check it at hot idle, actual and requested should match. After a few minutes of idle time, the EGR will shut off, and the actual will jump up (MAF), usually about 200-250. Rev the engine, let it return to idle, then it should go back to matching requested.
If it is NOT, you can check (while it is still commanding EGR), the vacuum to the line (the big one to the valve itself). There should be some there.
Then, using a vacuum pump (or a small length of tube and your lungs, it works) and see if you can operate the EGR valve directly. If not, if it will not hold vacuum, it is bad.
Keep in mind, the DTC "EGR excessive flow" actually means "MAF excessive flow" because the EGR is not working properly, no idea why VAG does that, but they do.
What I suspect is, your EGR is bad, vacuum is being bled off through the broken inner workings, causing low system vacuum in general, which is causing not quite ideal VNT control, which can cause a slight loss of power, especially at tip in.
www.cardocautomotive.com
Old May 15th, 2019, 09:30   #6
B-Line
TDI(s): 2001 Jetta
Thanks for the help. I did pull vacuum on the EGR and it opens and holds with vacuum applied.
Old May 16th, 2019, 03:34   #7
tgray
You may have a clogged EGR cooler with that many miles. A blocked cooler will give the same reading to the computer as disconnecting the EGR. Pull off the short tube that goes into the egr and start the engine. See how much exhaust blows out if any. Try gently pushing something like a copper electrical wire up the tubes to see if they are open.
tgray is offline   Reply With Quote
P0402 code will not go away. Help CALL911 VW MKIV-A4 TDIs (VE and PD) 18 March 9th, 2017 14:31
P0402 Fault Code Fcmilt VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 September 3rd, 2015 06:35
code P0402 breenybaby TDI 101 6 July 26th, 2014 15:36
P0402 Code gatdi2001 VW MKIV-A4 TDIs (VE and PD) 1 August 21st, 2011 14:38
Code P0402 Ralphpowell VW MKIV-A4 TDIs (VE and PD) 2 October 27th, 2005 21:40
ゥ 1996 - 2017, All Rights Reserved
Page generated in 0.13631 seconds with 12 queries
[Output: 81.02 Kb. compressed to 70.59 Kb. by saving 10.43 Kb. (12.88%)]
