mjydrafter
Hi there TDI folks. I have some ALH parts for sale. Pulled from my sons crashed 2000 sedan. 240K
O2J 5 speed. No clutch (PP was broken in 2 & this was an original according to the PO). Shifter box & cables, starter, wiring harness, coolant flange with glow plugs. The axles got bent, and the clutch pedal got broken as well (I think the return spring). I have the pedal, and you are welcome to it if you would like it. I also pulled some of the wiring harnesses. The starter will be included along with a bunch of fasteners. The only thing I think it needs is the shift tower bearing. It's been updated with the newer style shifter cable ends.
I pulled everything I could think of for a tranny swap. You may need some additional parts. The shifter is missing the bushings, as it had recently had a DG kit installed. I pulled that and used it on my car. (I will include all of the removed bushings and stuff, heck even the stuff from my car just in case, but I would recommend just getting the DG kit and be done with it.) LOL
Transmission & parts: $450 Sold!
ALH head w/cam, sprocket, lifters and vacuum pump: $200 SOLD!
ALH ECU: $50 SOLD!
Set of used injectors: $75 SOLD!
Original 10mm pump (240k): $150
11mm I pulled from the JY (189k): $200 SOLD!
Intake I pulled (not cleaned, but decent): $50 SOLD!
Recently cleaned intake from the engine: $75 SOLD!
ALH alternator: $100
ALH (reman) powersteering pump: $30
I have the short block, and I'm thinking I may tear it down. I'm assuming that the only thing worth getting out is the crank, pistons and rods. So when I get them pulled I will add them to the ad.
If anyone needs a picture of anything else just let me know and I can dig stuff out and take one. All of the parts look like just like used auto parts...
Also, I have a bunch of under-hood odds and ends, feel free to ask about anything you don't see.
All prices are OBO, buyer pays shipping (if needed). Parts are located in Des Moines, Iowa.
ALH ECU: $50 SOLD!
