GMCpatrick
- Joined
- Aug 16, 2001
- Location
- Atlanta
Well, we're getting our requisite 4 weeks of winter in Georgia and my Passat has developed a hard start problem in the cold. At first I suspected bad glow plugs or harness, but now I'm suspecting the coolant temp sensor.
The symptoms, hard starting(unheated garage - cranks about 10 seconds before starting on one or two cylinders and about another 10 seconds before the other cylinders start), lots of white smoke(unburned fuel) and slow warm up. No CEL and the glow plug light only illuminates for a couple seconds regardless ambient temperature. Once warmed up, it starts easily. With these symptoms and no CEL, must be the coolant sender - or am I all wet??
In the Bentley, I see reference to G2 and G62. Are these two circuits in the same sender?? In ETKA, it appears that there's one unit with multiple choices(I understand the color thing - I need to check and see which I have now).
Right now I'm planning to pick one up on the way home - any other ideas?
Thanks!
Patrick
Thanks!
Patrick
