This controller is a lot faster and more powerful than most, and it eliminates the need for an injection pump. Getting the same power from biodiesel as petrodiesel is an amazing feat. I like this company because of their digital valve technology too, controlling the fuel and the air takes closed loop to the next level.
http://www.jgpress.com/archives/_free/002422.html
Excerpt from the above article,
"For example, the company has converted a Volkswagen Jetta engine in its Woodland Park facility to be “more flexible and more intelligent,” says Sturman. “We removed the mechanical camshaft and the fuel injector and programmed the microprocessor to send instructions to the digital valves so we can open and close other valves that control the fuel, the air and the exhaust based on the program that the microprocessor is executing. Essentially, we’ve removed the mechanical controls that limit the performance, but kept the engine itself the same. This research, along with work we have done on other automotive, truck and stationary engines, proves that retrofits of existing engines are possible.”
No Injection Pump, no Timing Belt. Now that's a TDI everyone could love. This could be a solution to the high pressures associated with Common Rail motors too. Also it can turn 12,000 rpm, how fast would your car go at 12,000 rpm?
