For sale VNT conversion kit (used) for B4/A3 AHU/1Z with wastegate turbo.
Parts included:
All parts will be plug 'n' play, you just need a welding job for the downpipe.
N75 conversion is also easy: Remove N75 wastegate solenoid with all lines, put N75 for VNT in place , cut vacuum hose from vac pump near EGR valve, put a t-connector in place and run a line to N75. Connect N75 output to turbo actuator -> Done.
Then you need a tune for VNT turbo and you are ready to go.
There are many turbos (separate to the manifold) that can be used plug 'n' play with this kit:
If you need to keep the EGR functional, you can use a driver side PD130 intake manifold. I have one with P/N 038129713AJ for sale here: http://forums.tdiclub.com/showthread.php?t=340321
With AHU you can keep your mani and use a AFN EGR (elbow) pipe.
I can separate parts if needed.
Price $350 delivered (worldwide incl. insurance)
Parts included:
- AFN exhaust manifold
- AFN turbo inlet pipe
- AFN intercooler pipe
- AFN oil feed + return line
- AFN downpipe flange
- AFN N75 valve with bracket and vacuum line
- Manifold and downpipe gasket (new)
- GT1544V, GT1549V (VNT15)
- GT1749V, GT1749VA (VNT17)
- Borg Warner (KKK) BV43
- custom turbos like GT1752V (VNT 17/22), GT1756V, GT1856V etc.
