norel
After swapping the drivetrain/wiring from my daily (03 alh 5 speed) ,to an 04 1.8t auto car, I suddenly have some form of traction control. I'm guessing this is because I used the abs controller from the 04 car. Obviously the 03 harness had wiring in place to make the traction control light come on. (I completely swapped body/engine harness) Will it have wiring in place to add switch to turn it off? Would the 04 have had a switch for this purpose? Where would it be in the car? Traction control works, I just dont like it. Hoping I dont need to swap brake controllers to disable it while keeping abs. Thanks.
