If this post needs to be moved, I apologize for any inconvenience, but where else would I find a few blown turbos? /images/graemlins/smile.gif
My turbo (I think) is fine, but I have a bad actuator as the diaphram on mine is leaking and causing all kinds of control loop problems - like overboost - and it's out of warranty. I can't afford a whole new turbo just because I have a little problem like this with the actuator so, if you have a blown turbo and the actuator is still good, would you consider being an organ donor? If I can't fix my problem, I can't really dyno at the NE dyno day as all I do is go for a short fast ride and throw codes.
All I need is the actuator/plunger part. I can use my old control rod if you want to keep yours. If pity is not enough and cash helps I am also willing to pay. I have an A4 Jetta with 5-speed, but I think they all use the same turbo and actuator.
If you can help me out, please send email to chyoung@verizon.net. Thanks in advance!
--Betzel
--Betzel
