Millennium Falcon
The car is in the shop getting an "enhanced inspection" So I can register and drive it. Fingers crossed that it passes......IT BETTER! all the work I put into it!
You'll need a shifter boot for a Jetta as the Beetle unit wont fit your Jetta console. I usually just get a new one off Ebay with a new knob and chrome bezel around the boot.You have done a beautiful job on converting this wagon to a 5-speed. Congratulations! Hope it will serve you well for many years to come, and it should, given the relatively low miles on the engine. I have a 2002 sedan, TDI, with an automatic. I bought a used manual tranny from a 2001 Beetle TDI at our local Pull-a-Part yard, with hopes of swapping the manual into the Jetta. Unfortunately, the Beetle was already parted out (engine and ECU) leaving only the tranny. Many of the bolts and nuts were removed, however, the tranny still had the sensors, slave cylinder, and shift tower and cables, clutch peddle and CV axles left behind. What suggestions do you have for such a project to start with before I dive into this work? Did you have to have someone help with removing the old tranny or installing the manual? or did you do it all by yourself? Would you have done anything different if you were do it over again? Many thanks for your input.
I have a car lift so is it best to take it out the bottomUnless you have a lift, engine out the top. Engine swaps are easy enough for these little cars.
2001 and 2003 ECUs aren't interchangeable. Even if they were, you'd have to have someone delete the immobilizer. You can swap the auto ECU to manual with VCDS.
If you want a small bump in power swap the injectors from the manual to the automatic. Autos have higher pressure injection pumps and smaller nozzles. The bigger ones will give you a bit more power. Buy a 3-bar MAP and you've got a poor man's tune.
Good to see someone bringing back another wagon.
