MOGolf
- Joined
- Jun 27, 2001
- Location
- underneath something
- TDI
- 2001 Golf GLS TDI Reflex silver, rough road suspension and steel skid plate, 2004 Passat Variant, Candy White, rough road suspension and geared balanced shaft module, and much, much more. 2016 LR RR HSE TD6, 2019 Jaguar I-PACE
On the Golf sedan, Golf/Bora/Jetta Variant/Estate/wagon, and Passat Variant/Estate/wagon models the rear washer nozzle is supposed to be in a fixed position. If yours rotates with the wiper, or you get no washer fluid out of the nozzle, you have a problem. The latter case may be that the water tube through the wiper shaft has snapped off. Rotation indicates the water tube has seized in the wiper shaft.
Here's how to fix it. Too many pictures to post in a thread so I spent the time to make a PDF.
Tools needed:
Follow the instructions in the kit, or the modified instructions in How_to_Repair_the_Rotating_Rear_Washer_Nozzle.pdf
The most difficult part is removing the hatch inner trim panel. Read the PDF. Use whatever small tool (pick tool?) you have to aid in separating the trim pieces as required.
My Golf posed for the pictures in the PDF. Allow for any differences that might exist based on the model you have.
Tools needed:
- the repair kit 8L0 998 711
- a cross head screwdriver
- 13mm socket/wrench/adjustable wrench
- 10mm socket/wrench/nut driver
- T15 Torx screwdriver
- a strip of vinyl electrical tape
