Old September 14th, 2017, 06:30   #16
mk3pd
If exhaust gases are bypassed between Turbo and DPF
Where are you sending the exhaust gases to?
If to open air it will for sure be audible,if back to exhaust after DPF it will be measurable at MOT,so......
www.rosten-performance.com
mk3pd is offline   Reply With Quote
Old September 14th, 2017, 12:35   #17
TDIfreak
The only viable place for the wastegate would be between turbo and DPF, to reduce backpressure caused by the DPF. And it should not open in the MOT test of course. Gases should be routed back to the exhaust after DPF if you don't like the noise.
I like this idea .
TDIfreak is offline   Reply With Quote
Old September 14th, 2017, 13:37   #18
FraggyTDI
TDI(s): 04 Jetta
A wastegate wouldn't be the best option an exhaust dump controlled by boost pressure would be better. However if you bypass to much exhaust at higher rpms then you risk not getting your dpf hot enough to light it off to regen. This would lead to plugging your dpf sooner. So the best way to do it would be to have a switch on an electric exhaust dump so during non test times you just have the dump open bypassing the dpf. Then when you have the test close the dump and run it straight through the dpf.
Here's a super simple one that you can control mechanically then you wouldn't need to find a power source
http://www.jegs.com/i/JEGS/555/30862/10002/-1?CAWELAID=1710703006&CAGPSPN=pla&CAAGID=397144137 03&CATCI=aud-300525381019la-484224304472&CATARGETID=230006180039220951&cadevic e=c&gclid=Cj0KCQjw0ejNBRCYARIsACEBhDOOzCMzkz7QAt7Y hpX1tbNoC2_ngx93tju9KEyhPdoBdK8dOouzZ0oaAueGEALw_w cB
FraggyTDI is offline   Reply With Quote
Old September 14th, 2017, 15:28   #19
tom101
I like this idea .
yes, thats the idea. The wastegate only would open at high charge, and would make noise. A pipe direct to the floor for this exhaust can be fitted.
The wastegates I've seen have 38 & 44 milimeters. Enought to reduce the backpressure created by the dpf
Of course wont open at the MOT.
tom101 is offline   Reply With Quote
A4 3.0 TDI (B8) DPF back full 3" exhaust system Bobby Singh Private TDI Items for Sale/Wanted 3 February 24th, 2016 07:34
VW Mk6 TDI exhaust / DPF , EGR ETC. F/S Sctdi123 Private TDI Items for Sale/Wanted 16 December 3rd, 2015 12:27
Mk6 tdi dpf/exhaust for sale. Diesel252 Private TDI Items for Sale/Wanted 2 October 13th, 2015 06:41
Milltek GTD DPF back exhaust on CR 140 TDI??? baj0411 TDI 101 0 February 18th, 2015 17:18
WTB: rawtek full exhaust/dpf kit for my TDI. tbone1989 Private TDI Items for Sale/Wanted 5 May 20th, 2013 17:40
Page generated in 0.12594 seconds with 12 queries
[Output: 65.35 Kb. compressed to 58.84 Kb. by saving 6.51 Kb. (9.96%)]
