9mmkungfu
2006 Jetta w/ BRM - EGR cooler + turbo issue + shift module?
Car: 2006 Jetta TDI w/ BRM, DSG, 220k, stock
CEL codes: P0299 (Turbo underboost), P0673 (Glow plug cylinder 3), U0103 (lost comm with gear shift mod)
Problem: Intermittently, from about 1500-2000 RPMs, the car hisses and there is a loss of power.
Temporary solution: A quick restart and the problem disappears.
According to a local TDI guru, the turbo is seeping a little oil and the EGR cooler appears to be bad (soot on the back of the engine).
Right now, I'm thinking of replacing the turbo and EGR cooler. Am I on the right track?
On a side note, why does the problem temporarily disappear when the car is restarted?
As far as the other two codes (glow plug and shift module), I am thinking of testing the glow plug system with the glow plug 101 write up. The shift module seems to be in the shifter assembly itself, no? Also, the problem has not exhibited itself in quite some time; only the code remains. I'm thinking about clearing it and seeing if it ever returns.
