Used bio diesel for the first time today, was just wondering as its an old 96 car and never used this diesel b4 the best time to change the fuel filter as i intend to run it from now on, any other tips?
Change the filter in a couple of thousand miles... and carry a spare with you and the tools to change it on the fly if necessary.
Do a search for "viton" and "injector" for info on changing the inter-injector leak-off return lines. These lines are biodiesel compatible, but tend to get brittle with age and heat (regardless of whether you use biodiesel or not)...
