newbee
- Joined
- Jul 30, 2004
- Location
- Bernalillo, New Mexico
- TDI
- 99 NB (RIP), 96 B4V(gone but not forgotten), 15 GSW
First off, I’m the sort that believes there is a story to go along with every car, so if you want “just the facts,” skip to the bulleted points below. I for one, always felt better knowing the person and the relationship to the car as well as its history when purchasing a car, so what follows is a bit of the story behind this car.
I purchased our beloved ‘96 Passat wagon from the original owner in 2012. I had been looking for something more spacious than our NB TDI and had decided that my dream car would be a B4V, but they were too hard to find at a reasonable price and they disappeared quickly. I finally found one by chance (a TDI loving co-worker said his friend’s father owned one back in the day and might still have it) and although it was a couple hundred miles away sitting unused in a barn, the owner assured me that it would be okay to drive home. It started right up and drove fine on our test drive, so my wife and I decided to plunk down the cash to have a better family car. It drove well on the way home and we were impressed by how quiet it was compared to our ‘99 Beetle, although the brakes were terrible. After getting the car home, it sat for a couple of days and I noticed a significant wet spot below the car – diesel. The fuel injection pump was leaking like a sieve, (all over the coolant hoses) and so I set about finding out what I needed to do to repair that and to make this my dream car. It took nearly a year for me to get the car finished and I finally had it drive-able with the following repairs and upgrades:
In the meantime, VW was finally permitted to sell the 2015 TDIs languishing at its dealerships, and my wife pleaded with me to spend less time working on cars – couldn’t we just try one of the new TDIs out? So when we drove home with a 2015 Sportwagen, it was decided that we sell the Passat. A year later, I’m finally getting up the nerve to say goodbye to my beloved project car. It is reshod with 16” rims and Yokohama YK780s with just over 10k on them, the paint has been cleaned up, and it is ready to go.
Issues:
Now the only problem is I'm not sure how much to sell it for. I was hoping for $6500 without the spare motor. Is this reasonable? I'm open to opinions from forum members and will take it all in consideration.
I don't seem to be able to post photos, so please see photos here: https://photos.app.goo.gl/v9Y4BjEp7HBobrE36
- Injection pump seal kit from Dieselgeek w/ Viton pump head seal upgrade
- New rubber coolant hoses below IP
- New thermostat and plastic elbow
- TB kit from Dieselgeek w/water pump
- Steel serpentine belt tensioner roller w/ big bearing (upgrade seen somewhere on this forum)
- Air filter, cabin filter, Mobil Delvac 1 and Mann oil filter
- Coolant flush and G12+ coolant
- Clean intake manifold
- New rear stub axles and new wheel bearings all around
- Redline synthetic gear oil for transmission
- New tie rod ends
- Repack CV joints and new boots
- Polyurethane and Audi TT control arm bushings
- Koni Sport (yellow) shocks and struts with new strut mounts and bearings
- Eurospec 11” rotor rear brake upgrade kit from ECS
- Girling G60 11” front brakes – new rotors and caliper carriers, used calipers (purchased on TDI club) with caliper rebuild kit
- New 25.4mm ATE master cylinder
- 15” alloy rims and Yokohama YK580s to clear the brakes
- Alignment
- Solar Guard Ultra 20% window film on all but windshield
- Redline leather shifter and e-brake boots
- Sony stereo and speakers, w/ Bluetooth and hands free
- 15” full sized spare with alloy rim
- Weathertech mats and cargoliner
- Fumoto drain valve
- New vacuum lines
- New fresh/recirculating air flap controller
- New antenna (from Dodge Nitro)
- 9005 low beam bulb mod
- [FONT="]Meirsatz liftgate struts[/FONT]
Issues:
- Dome light/sunroof control panel cover is missing – all lights, and switches are there and work - as does the non-leaking sunroof - but the plastic surround is gone
- The switches in the door frames that control dome lights are broken or missing
- Switch that controls the side view mirrors, while still functioning, does not snap into place
- Stock drink holders are broken, as is rear ash tray
- Paint on the bumpers is in poor shape. I suspect that the body shop did not add enough flex additive to the plastic parts. My intention was going to be to use a bed liner type product to match the rocker panels
- VW factory rack cross bars were damaged on one end to force bike mounts off when car was stolen
- Carpet on passenger’s side appears to have had a floor mat glued down at one time
- There is a bit of black spray paint left under the TDI logo and at the upper edge of the hatch
- Plastic trim at the back edge of headliner is broken
- Rack and pinion boot is torn – have boots but have not installed
- Center brake light is broken
- Interior light above passenger’s side rear door is missing lens
- Instrument cluster replaced by first owner at about 100k miles
- Rearview mirror is missing
- This car was purchased new in Albuquerque and has by and large been a New Mexico car (it spent a brief time in its home country, Germany , as well as a time in Alaska, where they do not use salt, I am told) so it is amazingly rust free
- GQ/FA ECU with KermaTDI clutch saver tune (was going to upgrade the tune when the clutch finally needed to be replaced, but the darn thing still holds beatifully)
- Lots of extras: Bentley manuals – 2 volume print in like new condition (and CD), VAG-COM (Hex-USB), TB tools, spare rear bumper brackets (was going to fabricate a receiver hitch using these), factory roof rack cross bars (one end damaged, but easily straightenable), stock chips for GQ/FA ECU
- Yokohama YK780 tires w/ 10k miles
- Paint other than on bumpers is beautiful
- Free Carfax (I ran it figuring people would need/want this)
- All the upgrades and service listed earlier
- Synthetic oil at 10k intervals (sometimes Mobil Turbo Diesel/Delvac 1 and sometimes Rotella Synthetic and once Amsoil – all 5W40)
- If wanted, spare AHU/1Z motor with about 80k miles (originally purchased for TDI Type 2 conversion that never happened (extra cost for this – negotiable) and original BK ECU
