DanG144
What is the "VP"?dukku said:Does anyone have the VP conector pinout ?
Sounds like what my does right now. Is the car manual? ifso try push start it by towing it in second or third gear and get rpms over 2k and see if it woul fire up.ninedee_golf_tdi said:I have a pump on an alh that barely draws fuel (yes, it's primed, yes, drawing from separate container) and obviously barely sends fuel to the injectors. No obvious fuel leaks. Is it salvageable ? Thanks.
kline issueTaylorM said:well thats the thing it didnt die and the key light never flashed. I actually got no warning lights on the dash and my power still worked in the car. The vag-com showed no codes or anything. What is the K-line??
Can you post some pics of pump and metal shavings? also what exact seals you replaced? was it just head seal or completely resealed?sb10 said:My car has not started since before Christmas, I have always felt it was the IP. I tried to start it for a LONG time, while there was no fuel in the line. I have replaced the seal from dieselgeek and now the fuel holds, but it will not start. I finally pulled the top 2 seals to check the plunger and although it seemed fine...there were a fair amount of metal shavings that the magnet had grabbed. This leads me to believe my pump is DOA...I'm looking for a second opinion. Anyone please.
scott
TDIRookie said:FWIW, the whole Bosch VE manual (66 pages) that this came from is available from SAE's website (www.sae.org/ do a search for Bosch VE) in a PDF download for $14.95 US. I actually downloaded it this morning to use on my Dodge Cummins truck, wasn't sure that it was the same pump as the VW. IMHO, for $14.95, you can't beat it. Everything anyone wants to know about the way that the pump works should be in here. I used to write this stuff for a living and I would really recommend it.
Joe
chemglider said:I am a high school science teacher and a backyard mechanic with decent mechanical skills. As a summer project, I recently purchased a 1981 vw gas pickup that was in the process of being converted to a turbo diesel. I purchased the 1977-1984 Bentley diesel service manual. I am not getting fuel to the Injection Pump. I used a primer bulb to pump the fuel to the filter and past then clamp the hose to maintain pressure. (I placed a piece of clear hose in the fuel line to let me know if the fuel is in the line). When I hook the fuel line to the IP, the fuel seems to run back to the tank. When I crank the engine, the IP does not draw the fuel. I read this thread and could not find a solution. Any suggestions are truly appreciated.
The turbo pump has a diaphragm valve on top. It's attached to a pressure line from the intake. Basically, pressure on that guy moves stuff in the linkage on the pump and it injects more fuel under boost.chemglider said:I hear a click sound so I assume the fuel cutoff solenoid is operating. I have two other injection pumps I received when I purchased the truck. I was told there is a difference for injection pumps used for turbos. What is the difference? The other pumps I have look like the one that is in the truck.
