doodad
Hello
I'm in the process of my first TB change. I'm following the TB change pdf file, but I have a question about the tensioner.
So I started with the tensioner in the down position (the center of the two adjustment holes at the 6 o-clock position) with tab in the block and the nut hand tightend.
I rotate the cam part of the tensioner from 6 o-clock to about 3 o-clock clockwise and it rotates smoothly but the alignment marks are not aligned yet.
As I rotate to about 4 o-clock the tensioner sort of detents or is not as smooth as the 6 thru 3 rotation. My alignment marks line up after the rough patch of rotation, the tensioner tab is still in the block.
Is that roughness normal?
