Old June 13th, 2018, 18:45   #1
roadruner
TDI(s): 2012 mk6
Default MK4 1.8t to tdi swap help
Hi everyone, I'm new in this word and I need help with my mk4 swap.
I have 2 2002 jetta's. One 1.8t automatic with clean body but broken engine and another one tdi with perfect mechanics but rusted body.
I think make this swap because a love a diesel cars. if someone has done in the past, I would like to have tips about that.
I know I need to change all the mechanics and engine harness but my first question is, I need to change all electric harness? The dashboard harness to? Please help me.
Thanks.
roadruner is offline   Reply With Quote
Old June 19th, 2018, 14:15   #2
CasaEd
TDI(s): VW Passat B4
I've only ever done VP to PD swaps, but I know that when I made a
bench flashing cable I took it from a petrol engined car and I had to
rewire the main live feed and ECU earth wires because they were in
a different postion to the Diesel ECU plug, easy enough to do as with
the other wires in the plug if the are in the wrong postion. The dash
wiring is the same, but the Rev Counter won't read right as petrol and
Diesel are different
CasaEd is offline   Reply With Quote
Old Today, 06:16   #3
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Very easy swap. no need to change the entire harness. The TDI harness will plug into the car, minus a few moved pins.
Thanks.
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
schnellvw.com
GTiTDi is offline   Reply With Quote
Mk4 1.8T to TDI swap wiring grim_reaper888 TDI Conversions 4 February 20th, 2017 09:37
Will a Mk4 1.8T Dogbone fit a Mk4 TDI? Rembrant VW MKIV-A4 TDIs (VE and PD) 5 December 29th, 2014 03:23
Starter for a Audi A4 TDI Quattro swap with 1.8t M/T A4-TDI TDI 101 1 November 22nd, 2014 18:23
Insurance Dilemma- 1.8T Auto to ALH TDI Manual Swap PduBerer Ontario 2 January 9th, 2013 10:21
Anti-conversion swap engine from 1.9L TDI to 1.8T TDIHog TDI Conversions 18 May 1st, 2007 18:49
Page generated in 0.11623 seconds with 12 queries
[Output: 59.32 Kb. compressed to 54.00 Kb. by saving 5.32 Kb. (8.96%)]
