Old June 9th, 2018, 16:48   #16
rocketboy52
rocketboy52's Avatar
Dang it! My pics are not posting��
2004 VW Passat GLS TDI 221k
1999 F250 7.3l Powerstroke 283k
DIY Chainless Since 11/2011
rocketboy52 is offline   Reply With Quote
Old June 9th, 2018, 23:12   #17
DeliveryValve
Sorry you are going through all those issues.
Are you talking about the axle flange?
Here is video on one technique to remove it.
https://www.youtube.com/watch?v=-ta4EEOyzKw
The flange seems to have the same type of clip the CV joint uses on the axle. It just clips in and to remove it, you hammer it out. A slide hammer should work also. But try the method on the video first.
- Richard-
2005 Passat TDI GLS Wagon 207,xxx miles - Chainless
DeliveryValve is offline   Reply With Quote
Old June 10th, 2018, 01:10   #18
rocketboy52
Delivery Valve, thanks for the link. I ended up working on her for more than 12 hours today, and I finally have some progress, but I'm still super frustrated that despite all the reading I've done of others doing this swap, I never once heard of anyone else with this issue of not getting the sensor in the transmission.
As another good thing, I figured out how to edit my previous posts and reduce the size of the pictures. The previous pics where HUGE and were making it hard to follow this thread because the oversized pictures were making it hard to view. I also figured out why my previous posts pictures weren't posting correctly so that was good. Hosting the pics on my google drive is tricky. A note for future folks, you need to right click on the image you want to share and click "copy Image address". If you use the "create a link" function within google photos, it won't display once inserted into these threads.
Back to the car, I pulled the driver side wheel and axle. I really didn't want to pull the transmission again as its a real booger to bench press it in and get it lined up and hung. So I went back to the slide hammer route, I detached the lower A arm pivot pins where they attached to the sub frame. To get the pins out, I lowered the back of the subframe about an inch in order to gain clearance on the aft lower A-arm hinge bolt.
I then tied the wheel perch out of the way
With the wheel perch out of the way, I was able to get better access to the axle flange and using a 5 lbs slide hammer, the flange came out with 4 moderate slides.
Here is a few more shots of the parts after they came out:
I was hoping that the installation of the reluctor disc would be obvious, but the differential housing that the disc fits over only has one flat in the OD shaft where I assume the disc sits. It seems line the shaft should have two flats, one for each clip... The reluctor disc however has two brass clips that look like they should be latching on something, but it doesn't seem like there is any obvious features for the springs to clip into. It also wasn't obvious which way the disc gets installed. Any input or pictures would be great help!
Should I install it this way?
Or should I put it in this way?
Can anyone confirm if I even have the right part? Earlier in this thread, soeme of the previous comments talked about a disc that had lots of "teeth". Since this transmission didn't have the part installed, I don't have a "good example" of the installation to imitate.
Thanks in advance. One other follow up for others who might someday come across this, I spent 10 hours on this today, about 5 of them was trying to figure out how to fit the slide hammer in the axle hole without crashing into the wheel perch. knowing what I know now, it would have probably been about the same amount of time to pull the transmission again...doh!
Old June 10th, 2018, 08:27   #19
QuickTD
The ring is installed as per your second image. Here is a link to a photo
https://cdn4.pelicanparts.com/techar...mall/Pic04.jpg
This is a Porsche boxster transaxle, but it is the same unit used by vw/audi.
For future reference, the easy way to remove a drive flange is to thread 2 all-thread 10mm bolts through the drive flange and allow them to bear against a couple pieces of flat steel bar placed against the trans case. The manual shows tire irons but any flat bar about 1/4" x 1" will do. Alternately tighten the bolts until the drive flange is pushed from the case. I've changed lots of them this way.
Wish I would have got here sooner, the slide hammer looks like a lot of work...
QuickTD is offline   Reply With Quote
Old June 13th, 2018, 09:23   #20
rocketboy52
Quick TD,
Thanks for the response and the links to the picture. The shaft in the differential that the reluctor wheel slips on, has only one "flat" but the reluctor wheel has two spung brass clips.
There is also a machined groove in the shaft that looks like the reluctor clips would clip into.
Is there any special orientation to install the reluctor disc onto the shaft?
The Youtube video that you sent that describes using a long bolt to drive the axle flange out definitely looks like it would be less work, hopefully someone in the future will benefit from this discussion.
Thanks!
Old June 13th, 2018, 14:05   #21
QuickTD
To be honest, I've never installed a reluctor ring. I have had transaxles apart and looked at them but didn't take much notice...
The ring can go on in any radial orientation, unless there is some molded detail in the plastic ring that would serve to index it on the flat. I can't see any such detail in the pictures. The ring just has 4 magnets that switch the sensor 4 times per revolution, requires no torque to drive it. I would orient it such that the clips are in the groove. It looks like the flat is deeper than the clip groove, so avoid placing a clip on the flat.
Older models used a gear for the speedo drive and that setup required the gear to deliver a small amount of torque, so the flat may just be some legacy thing.
Old June 17th, 2018, 00:44   #22
rocketboy52
I got the car back together tonight. I installed the reluctor ring with the spring clips 90 out from the notch and pushed it on until the springs clicked into the grove on the shaft. After getting all the parts back on I took her for a drive. I'm super excited to have her all back and working. I still have four idiot lights to resolve, but I think I have all the answers and just need to get all the cruise control and brake wiring under the dash correct. I think the one thing I wish I had known before I installed the transmission, is I wish I new to double check to see if there was a reluctor wheel installed in the transmission I recieved. Frans hooked me up by sending me the missing part, but it would have been alot less work to have installed it while the tranny was out of the car. For anyone who gets a 5 speed to make the swap in the future, just know, that if there is a "plug" vs a VSS sensor in the speedometer sensor spot, I would guess there is no reluctor wheel installed. That was my experience anyway.
Brake issues....booster problem? rotarydiesel TDI 101 4 September 19th, 2012 13:01
Brake Issues After New Booster Installed iMac6 TDI 101 4 July 26th, 2010 04:17
New Brake Issues After Booster Replacement iMac6 VW MKIV-A4 TDIs (VE and PD) 0 July 17th, 2010 12:52
5 speed tranny issues please HELP!!!! levit99 TDI 101 4 July 6th, 2007 18:50
Faulty Brake booster = auto tranny & brake prob. firecopter VW MKIV-A4 TDIs (VE and PD) 6 October 20th, 2004 07:58
Page generated in 0.13218 seconds with 12 queries
[Output: 93.45 Kb. compressed to 82.56 Kb. by saving 10.89 Kb. (11.65%)]
