Old June 12th, 2018, 13:47   #1
commanderjjones
Default oil cap leaking
Noticed when I changed my oil yesterday that I had a significantly amount that had leaked around the cap. Not overfilled and this is the first time I've seen it happen. Is the cap just worn out (the car does have 350k)? Doesn't seem to fit loosely, but I think it should seal enough for that to not be happening.
commanderjjones is offline   Reply With Quote
Old June 12th, 2018, 14:59   #2
hey_allen
You can buy just a seal and replace it, as the seals do harden and stop sealing well after some length of time.
I've purchased a couple over the years, usually from one of the forum vendors, as a small add-on item tossed in when I'm ordering other maintenance parts or supplies.
hey_allen is offline   Reply With Quote
Old June 12th, 2018, 15:05   #3
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Old June 13th, 2018, 03:58   #4
Dieselmonkey02
TDI(s): 02 jetta
Fuel Economy: 48-50 avg. 44 lowest 54.6 highest
Mine was leaky before, I just pulled the seal off and cleaned it real good and it’s been fine since.
Dieselmonkey02 is offline   Reply With Quote
Old June 13th, 2018, 19:33   #5
KyleMillione
Fuel Economy: 02 (auto) 39, 03 (man) 48
I put 2 seals on mine to stop the leak. I think the metal tabs that hold the cap in get little bent after 200k, and putting the extra seal keeps it tight. I'm relatively sure I got it at AutoZone.
2002 Green Jetta Auto 220k RIP
2002 Black Jetta Auto 240k
2003 Silver Jetta 5sp 290k
KyleMillione is online now   Reply With Quote
Old June 13th, 2018, 21:04   #6
KrashDH
TDI(s): 2002 Golf
I just bought one at Napa this afternoon for safe measures as well. Hope I don't need 2?! I'll buy a new cap if that's the case!
KrashDH is offline   Reply With Quote
Old June 14th, 2018, 05:25   #7
oilhammer's Avatar
Fuel Economy: fantastic
My Golf always has some slight wetness around the cap... I've replaced the seal, replaced the cap, different valve cover at last t-belt change even... still does it. Not awful, not anything I am really concerned with... but after 540k miles, I guess if that is really the worst thing, then that's OK.
www.cardocautomotive.com
Old June 14th, 2018, 11:02   #8
hey_allen
I bought a steel oil cap at Oreilly's the last time I was looking for a seal, and it has a bit more tension on the spring that holds the cap down.
So far seems to be keeping mine dry, but it may loosen over time as well.
I had replaced the stock cap's gasket previously, and it worked for a while before it started to weep again.
Old June 14th, 2018, 18:37   #9
KyleMillione
I just added the new one with the old one. I'm relatively cheap and the seal was cheaper than the cap.
Is this my oil cap leaking OR? Savageman69 TDI 101 14 June 5th, 2010 08:09
Oil Filter Cap Leaking? High Oil Pressure? Jeepmb VW MKIV-A4 TDIs (VE and PD) 16 January 20th, 2010 04:42
Oil Cap Leaking SheeB VW MKIV-A4 TDIs (VE and PD) 2 March 22nd, 2009 18:59
leaking oil cap major-poser VW MKIV-A4 TDIs (VE and PD) 7 May 25th, 2004 12:53
leaking oil cap major-poser VW MKIV-A4 TDIs (VE and PD) 1 May 23rd, 2004 17:50
Page generated in 0.13594 seconds with 12 queries
[Output: 88.60 Kb. compressed to 75.72 Kb. by saving 12.88 Kb. (14.54%)]
