Old June 9th, 2018, 23:53   #1
CrossGolf
Default Violent Shaking on Acceleration
Since last week our car (57 plate 1.9 tdi VW Cross Golf, based on Golf Plus) has begun shaking really violently when accelerating. It isnít felt through the steering wheel, literally the entire car is shaking and all passengers can feel it. It only happens on acceleration and as soon as I lift my foot off, it stops. If I depress the clutch, it stops immediately too. Itís mostly felt between 1800-2200 revs and will eventually even out at more than that. Worse in 4th and 5th gears.
Weíve done:
New front drive shafts both sides (Shaftec)
Fuel filter
DMF (replaced with Valeo single mass conversion kit, I know there are fors and againsts for this...)
Clutch (done with DMF)
Oil filter
Oil change
Front shocks (<5k)
New front springs (<5k)
New drop links
Weíve checked but not replaced
Engine mounts
Dog bone
Swapped the front wheels to the back
Now weíre out of ideas. Everything points to worn Inner CV Joints but the new driveshafts have made no difference. I have heard of aftermarket shafts causing this issue so would it be worth getting some second hand genuine OEM shafts or am I just throwing good money after bad?
What else could it possibly be? Grateful for any advice. Thank you.
CrossGolf is offline   Reply With Quote
Old June 10th, 2018, 04:07   #2
RabbitGTI
RabbitGTI's Avatar
Fuel Economy: Don't know. I just feed it and drive.
Check the control arm bushings. I had a similar problem and that was it.
Rabbit GTI racecar RIP, 84 Rabbit GTI, 88 Golf GL, 97 Passat TDI, 07 Jetta 2.5, 02 Beetle 2.0, 08 Jetta 2.5 with Aisin Box.
RabbitGTI is offline   Reply With Quote
Old June 10th, 2018, 07:25   #3
Dannyboy
Dannyboy's Avatar
Fuel Economy: 2014- 1168km per tank
^^^ X2
Usually rear control arm bushing. Don't know if R32/ audi tt ones will fit yours but they were a good upgrade on mine
Dannyboy is offline   Reply With Quote
Old June 10th, 2018, 10:25   #4
boertje
boertje's Avatar
I had something very similar on my alh bug some years ago. It turned out to be a bad injector. I know, different fuel system but might be worth investigating.
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is online now   Reply With Quote
Old June 11th, 2018, 00:28   #5
CrossGolf
Had the car on ramps yesterday and inspected all bushes. All look great, no play or movement whatsoever. Replaced the engine/gearbox mount (passenger side on U.K. car) and no difference. We also put the new cv joint on the original oem drive shaft and no difference there either.
Weíve got a code reader and itís not throwing up any codes at all which I would expect it to if there was an injector issue?
Iím so confused!!
Old June 11th, 2018, 00:31   #6
CrossGolf
Just to add... The car is running perfectly, better than ever before and I ran it up to 80mph on axle stands and it didnít make shake until 80 and even then only a minor vibration, not the bone shaking it usually does when driving.
Old June 11th, 2018, 04:22   #7
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
had one PD car that felt like axle vibration and it ended up being flat cam. Ran fine at idle but once loaded up the engine would misfire shaking the car. Pull the valve cover and inspect the cam.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old June 11th, 2018, 07:20   #8
Dannyboy
Dannyboy's Avatar
Have you checked for play in the gearbox output flange When the axles were off? I know Seat tdi gearboxes around that particular year were notorious for problems, not familiar with golf cross one.
How are the wheel bearings?
Have you looked at the back axle yet?
Old June 11th, 2018, 08:18   #9
87vdubgti16v
Mine had a violent death wobble check side to side play on both axles. Changed my axle shake went away
87vdubgti16v is offline   Reply With Quote
Old June 11th, 2018, 11:03   #10
CrossGolf
Checked all the bushes at the back and no movement at all there. They all look fine. Rear axle is fine too but rear shock absorbers are completely shot. Got more to replace them tonight. Wheel bearings also seem fine, no noises from them.
The camshaft thing is looking the most likely possibility at the moment, sadly.
The car has done 129k so could very well be the case, however Iím surprised that itís come on so suddenly. Literally fine one day and death rattle (great analogy!) the next. I took it out for a spin this morning with a friend for their opinion and noticed it drove perfectly when cold. As soon as we got up to temperature, the shaking was back with a vengeance. Puzzling.
Old June 11th, 2018, 11:58   #11
Nevada_TDI
When you replaced the rear dampers, did you replace the bushings/mounts for them too? I don't know if your car has them or not, but worn shock mounts will rattle too.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Old June 11th, 2018, 13:29   #12
CrossGolf
YOU ARE MY SAVIOUR!!!!!
Took the valve cover off and the cams are really badly worn. New camshaft it is then!
Thank you! Thank you! Thank you!
Old June 14th, 2018, 06:51   #13
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Awe shucks...
FYI... got a youtube channel with tons of Vw diagnosis info. You should subscribe (link in signature below). When I come to the UK I want you to buy me a dinner! Might be 5-10 years from now.
Nailed
Violent Shaking In Reverse Richey VW B5 Passat TDIs 2 July 6th, 2017 08:05
Violent shaking especially on hills cabloom44 VW MKIV-A4 TDIs (VE and PD) 1 October 19th, 2015 21:31
violent shaking of engine bay passatv6af VW Passat Family (NMS and B7) TDIs (2012+) 2 January 14th, 2015 19:38
violent shaking mattro TDI 101 2 March 17th, 2013 07:41
Violent shaking when accelerating...help! jshinejr TDI 101 39 December 20th, 2011 16:28
Page generated in 0.18340 seconds with 12 queries
[Output: 114.99 Kb. compressed to 96.55 Kb. by saving 18.44 Kb. (16.04%)]
