AlanTDI
- Joined
- Apr 18, 2002
- TDI
- 1996 Passat wagonTDI, 02 jetta sedan, on the dark side 2017 Rav4
Hi:
I have to change /flush the coolant in my 99 Golf as it is brownish.
I know to drain radiator and disconnect hose to drain engine, remove thermostat (have to get a gasket first).
Is there a recommended flush chemical? Or just use the garden hose water? I know prestone makes one, is it compatible with G12? (probably not).
Thanks in advance.
Thanks in advance.
