Indwelling
Car wont start and noticed no glow plug light.
Only code is camshaft sensor. Will that cause the glow plug light not to work?
Well finally got a few hours to mess with the car. Check the timing and it seems to be dead nuts on.sounds liek timing belt moved......
try replacing the belt if it isn't recent
Haven't really checked it while someone turned the key. Just by turning the crank manualy.you still notice the tb tensioner movement at cranking speed?
That is normal. As long as it returns to correct position when rotated by hand to #1 TDC in clockwise direction some movement of the tensioner is nothing to worry about. At hand-rotation speed the load on the belt as it turns the cam varies throughout the cam's rotation, causing the small changes in where the belt tension is distributed. The tensioner moves to take up or release the slack.Tho the one thing i did noticed while getting everything lined up was the tensioner pointer.
As you turned the crank the pointer would move from the middle of the window to just past the window
and then back to the middle as you came back around.
