sanslove
Hi all,
I'm a brand new owner of my in-laws' 2002 Jetta, and I just failed the Massachusetts emissions inspection, as the OBD test returned code P0673. I've looked through the glow plugs 101 thread and I feel that doing the diagnostic steps listed there for the #3 plug and the wiring harness are within my very limited mechanical ability, but I had a few questions that I was hoping someone could answer; I couldn't find any other threads directly answering these questions:
1) I am under the impression that replacing the glow plug or spraying DeOxit may truly solve the problem, but it won't clear the code. Does this mean that when I get the car re-inspected, it will still throw the code? If so, are there any straightforward ways of clearing the code myself?
2) A bad glow plug or harness doesn't seem like an emissions violation to me, but I've read that the MA emissions test recently changed, and any OBD fault will cause an inspection failure. Anyone know if this is indeed the case? I ask in part because the car has been through 7 upstate NY winters and has never had the exhaust system touched, so I figure we're in for a big repair in the coming year or so.
3) For full disclosure, the check engine light has been on for a while. My father-in-law had the code read a month or so ago and it indicated a bad thermostat. We're planning to get that replaced soon anyway, and so maybe if I can do the glow plug service myself, the shop will just clear all codes at once.
Thanks in advance for any advice!
