UhOh
How common is it that front brake calipers go bad? I know that the back ones are a weak link.
I'm in the middle of dealing with a bad front brake caliiper on the wife's car. The PO had front brake work done on the car at around 142k miles. New pads and rotors AND both calipers. I seem to recall that the invoice showed a pretty low cost on the calipers ($70 ea?), which would tend to suggest they were rebuilt ones.
This is, and, as far as all the records I dug up show, has always been a PNW car. Both front brake calipers bad at 142k miles? And now at 191k miles one is totally freezing up on me? Fluid struggles to come out of the bleeder valve: I have a Motive power bleeder hooked up.
The shop that did the brake work at 142k miles wasn't, to put it mildly, very good. I encountered, and on this same caliper, a stripped guide pin (I heli-coiled the knuckle- it took the pin torque fine). I wasn't able to replace all the pins, only one (the stripped one), the others sanded a bit, all got greased up. I suspect that once pins are at this stage that it's a lost battle.
I received new rotors and pads (my favorites- Zimmerman rotors and Akebono pads). I just ordered, from VW two new calipers (and all new pins). Is there anything I should be concerned about that might be happening to cause all of this to prematurely fail? I know how to install and grease things up correctly. I wouldn't think that the knuckle is causing any problems as the pin seemed to go in just fine: the brakes also seemed to be pretty good for a while (I'd have to look at my records, but I'm pretty sure the car has at least 10k miles since I did that heli-coil work).
If ever there was a car whose front calipers should be bad it's MY car! Everything sticking out from the axle looked like heck when I got my car with 114k miles on it: one brake pad had separated from its backing plate; rotors were actually delaminating; yet, the calipers work great (now with 157k miles). Go figure!
