BobnOH
not-a-mechanic
The electronic addition does gives you access to tech bulletins, current updates, campaign info and other resourcesThanks. Was considering the disc version, but for half the price, hard to go wrong with that.
Ha ha! Been there! After I'd gotten my first Golf TDI I was not happy with it at all. Lots of things needed repairing (but the engine was sound). After a lot of work, and some great parts, I wouldn't part with it. When you get these things back up to par and keep up with regular maintenance they're wonderful cars.Bentley manual is on its way. I totally agree with OEM parts. That's my plan. I think the pain from the initial cost will fade, and then I will be thankful down the road. I have a good buddy who owns a 03 Jetta TDI, and also owns a VAG-COM, so I am covered there also. Thanks for your help. #feelingrelieved.
Good Luck!
I remember my 03' Wagon jumping the timing belt the previous owner told me that he replaced (did not!!!) and it dropped the valves, bent some rods. Lots of money later that was the best car I ever owned. Sounds like you have good mechanical abilities, you'll do just fine.
As far as the two sensors. I'd say MAP sensor & MAF sensor.
I have never seen one of those weird flat lower pipes.
I agree, that is why I stayed with the 2 hole.IIRC, even though the difference in head gasket thicknesses is very small there is a tremendous difference in the final compression ratio. When the engine is not under full boost there is possibly and likely incomplete combustion occurring regardless of the size turbo being used.
