bbob203
What the highest recorded milage on a stock unmodified only maintained alh?
On these that Bob mentioned, it's still to early to tell.Been a few 500K, 600K, 900K mile ALHs.
*GROAN* and also LOL.not a ALH but my BEW has 325K
ALHs should not have an issue reaching 400K on their second injection pump
The cluster does stop counting at 1 million km, but the ECU still counts.I thought our ODO's froze at ±621,000... still a lot of miles.
Ah, one...On these that Bob mentioned, it's still to early to tell.
How long can a well maintained TDI engine last? The world may never know.....
I'll bet the clutch will last a long time if lets say it's "used properly" but probably more important it will last longest if theres only one user. Like just your driving habits patterns etc. I've seen it a few times where cars with high mile clutches go to new users and clutch has gone pretty quick....How long can a manual trans clutch go, assuming the user is experienced?
I always thought of clutches as 'wear items', even when used properly.
I have never personally had to change a clutch - but the most miles I've put on a manual transmission is about 65,000 miles.
Otherwise - I agree with the above - any engine can run forever, if continually rebuilt. Witness gas cars putting around from the early 1900's...
I also agree - with TDI's, its the body/interior that's likeliest to go before the engine. I searched for an 80's Mercedes Diesel - some/most are still running in good condition, but almost none have a decent interior. Power windows don't work, antenna doesn't work, sunroof totally dead, power locks intermittent, no A/C, heat works but is weak, seats torn...list goes on....
Agreed. I'm not gonna lie i'll give Chevy credit for that 5.3L Vortec engine. Almost 600k and all it's ever seen is routine maintenance...Evidence of durability is running for high miles without teardown.
Totally agree, the quicker you put the miles on the better chance you have!Used to work with a guy that had an old beater Nissan truck. He had at least 700-800k miles on it. Don't remember exactly. It was a pile and he was proud as a peacock despite its condition. Engine bay was a mess, paint gone, interior in shreds but it just kept on running. I wish I remember the exact mileage but we used to call it the Energizer Bunny.
I would be happy to reach 500k in mine. Time takes it's toll. I think the faster you can build up miles, the better chance you have of some extraordinary numbers. Lots of freeway cruising is relatively easy on most parts (wheel bearings aside) and plays to the strengths of our TDI engines.
I agree - the interior can last for as long as they are cared for - especially true if there's one owner throughout the life of a car, and they are diligent. But, time usually takes its toll - even on well-built Mercedes. Its hard enough to find an an older Mercedes in clean condition - older VW's are typically, well..... And all those little parts can be expensive and tedious to replace (often more expensive and tedious than engine repairs) - and that's only when you can even find the replacement parts.I also consider clutches wear items, and replacing them during the life of a car is something you can probably expect. We have one customer who got 545K out his original clutch in a TDI, however.
Body and interior bits will last if you take care of them and replace what breaks. Rust is the big problem here. I have a '93 M-B that looks new inside and out, and everything except the cruise control works. However, the car wintered in Florida and now rarely even sees rain.
