Oilman
I need a bit of advice, hopefully from someone who has encountered this:
I started the Install of my Panzer Skid Plate yesterday-Everything went fine, all sub-frame rivnuts went in fine, Torqued to 35 ft-lbs; Driver's side post installed fine-Then my problems started
For the passenger side post-As recommended in the instructions, I used the post as my Rivnut holder;The first Rivnut (Front)took some muscling, but eventually did go in and was torqued to 35 ft-lbs and then backed off slightly
The rear Rivnut however, would not cooperate and would only thread so far before it started spinning inside the Frame rail-after wearing myself out for an hour putting pressure on it to get it to bite, I took the post off and used the Rivnut tool-eventually it bit and I was able to torque it to 35 ft-lbs
So-I go to loosen the bolt to remove the Rivnut tool and-It again starts spinning in the Frame rail-The car can't be driven like this as the Rivnut tool is against the serpentine belt-I fought with it for an hour or better and finally was able to get the bolt out.
So-I now sit with two Rivnuts in the frame rail-one tight and the other loose-What do I do now?
my options as I see them:
1) Put the post on and hope that the rear bolt will bite and allow me to tighten it-hoping that if it doesn't, the front bolt gives sufficient structural support
2) Drill/Break out the "bad" Rivnut and try with the spare included in the kit; If I do that-what's the trick for getting it to "bite" right away? If it behaves again as the previous one-where do I go from there?
3) something I haven't considered?
Insights are greatly appreciated
Jay
Jay
