bhodgkiss
I assume this isnt possible, but what if I could
- Take gearbox off
- remove clutch/crank
- lower pistons down so that the rings are still in the bores but I can remove the rods
- fit my rosten rods (having measured centre to centre distances to ensure they match orignal items so that head gasket is still the correct thickness)
- push pistons back up from below
- re assemble everything with new main bolts etc.
My stock pistons are surely good for 250bhp/500Nm (AFN with 19.5:1 compression)
The benefits in this are that:
- my head is properly installed already with PD150 head bolts, and not leaking at almost 200bhp, so assembled nicely
- the head was off 30k miles ago and bores looked great still, so keeping piston rings would be fine in the bores I'm sure. HEad is already ported and been skimmed before.
- massive cost and effort saving as i dont need new head gasket, head skim, hone bores, new rings, etc etc
The rods are simply swapped from below and then allow huge power.
Is this impossible? To confirm, the pistons arent dropped out completely, just low enough to get onto the main pins to change the rods, whilst keeping rings in the bores so as not to need a ring compressor
I have a spare block thats stripped so can actually try this!
Now shoot me down!
- Take gearbox off
Now shoot me down!
