Old January 17th, 2019, 08:26   #31
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
The cables, the set I bought, the set the Mexican fellows had and the set my friend brought were/are all fairly thin. About 3/8" including insulation, rated at 600 amp.
So in other words not hefty enough for starting a Diesel.
Having said that, I did remember reading at one time running two sets of cables in parralell would work.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Old January 17th, 2019, 11:00   #32
ZippyNH
When my oem battery went, the car was almost impossible to jumpstart with cables.... found a mechanic with a big pick-up truck and a high output alternator, and after 5-10 minutes could crank with a HEAVY set of cables..., outside temp was about 33f/0c. Car would not crank off his work van. Guessing a cell failed internally. Remove and replace...even a cheap local battery would be ok for a couple months till you drive North...then drop into someplace and get one.
In my case, the battery showed zero signs of failure and DID read good volts on a jump pack readout with a built-in voltmeter that I keep around (car sits for 2 weeks or more at a time at airports, so I keep it in the trunk since I already own it, and at supposedly 800 amps for cranking upto a 3L Diesel, it couldn't do it). When not parked at an airport on a trip, sometimes it stays home in a heated garage with a battery tender when I use a car service....but about 4 years and 55k on an OEM battery, and it was done.
Ironic...I almost swapped it out in the fall due to age, but it seemed to crank well on colder days, and had good numbers on a free test.
2015 Jetta TDI SE, Silk Blue
previous-2005 MINI Cooper S, tuned and modded to 200+ HP
ZippyNH is offline   Reply With Quote
Old Yesterday, 17:28   #33
Jetta_Pilot
My friends today brought my new H8-AGM battery down for me. It's a Duralast Platinum "Made in Germany", by whom I don't know now.
900 cranking amps at 0
1000 cranking amps at 32
90 amp hrs
Thank you all for helping me.
Over and out!
2015 Sportwagen TDI S - Dead battery after 14 months vdubtc VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 5 August 7th, 2018 17:27
Battery upgrades for 2015 GSW? TDI4evah VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 16 February 12th, 2018 04:55
2015 TDI GSW SEL Proper Battery Size ? ritsco VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 12 September 21st, 2017 13:12
2015 GSW Car Battery replacemnt lriddick VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 23 August 2nd, 2017 04:02
2014 Passat SE upgraded to 2015 Passat SEL ZippyTDI VW Passat Family (NMS and B7) TDIs (2012+) 7 November 24th, 2014 09:08
Page generated in 0.11403 seconds with 12 queries
[Output: 61.88 Kb. compressed to 56.16 Kb. by saving 5.72 Kb. (9.24%)]
