Old January 14th, 2019, 11:17   #1
merf
TDI(s): golf
Default Replacement crank
Following on from my post about the engine nose I need to find a new crank and con rod for my BMM 2008 2.0 tdi PD 8V engine
The crank is 38AA and the rods are 038KJ
The crank has a small sprocket driving the oil pump and there is no balance shaft. And it's the type with less counter weights on.
I think I can fit a one from a different engine code as long as it's 38AA?
merf is offline   Reply With Quote
Crank seal replacement MOGolf VW MKIV-A4 TDIs (VE and PD) 121 Yesterday 09:33
Timing Belt Replacement, No Crank Counterhold RV9Factory VW MKV-A5 Golf/Jettas 12 July 15th, 2017 02:14
crank bolt replacement question iluvmydiesels VW MKIII-A3/B4 TDIs 17 December 27th, 2016 07:40
Crank Seal Replacement Near Boston gmenounos Eastern USA 1 August 24th, 2012 03:54
Help with front crank seal replacement ReferenceDesign TDI 101 3 October 23rd, 2008 12:19
Page generated in 0.11985 seconds with 12 queries
[Output: 46.82 Kb. compressed to 44.14 Kb. by saving 2.68 Kb. (5.72%)]
