Old January 13th, 2019, 13:38   #16
Owain@malonetuning
I'd personally do nozzles before a tune, that'll give you a taste of what's possible. 205-216 sections should be fine, you might need to raise your injection quantity a bit to keep bottom end smoke reasonable on 216s.
Mec evo or Giles @ performance diesel injection would probably be your cheapest options on this side of the border. Concept1 and CTS also have a no name 205 nozzle that's made in Italy that a lot of people have had good results with.
Sach vr clutch should be fine but agreed a south bend would be ideal for future proofing.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old January 13th, 2019, 15:12   #17
WildChild80
WildChild80's Avatar
I love my SB S2E, light pedal and holds the tq
WildChild80 is offline   Reply With Quote
Old January 13th, 2019, 17:42   #18
Nevada_TDI
Upgrading to .205 nozzles will give a lot more oomph and possibly not kill your FE either. By doing the nozzles first, it saves one step when getting a tune, and possibly moving to a Stage 3 tune after will provide a huge noticeable difference in power.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Old January 13th, 2019, 23:54   #19
03TDICommuter
Interested in reading what you end up doing. I'm in the same boat but a few less miles (355K). Previous owner did replace the clutch before I got it, but otherwise all other components are original including the turbo.
2003 Jetta TDI, 5 spd, 353K miles, original engine/turbo
- 319,300 miles - turbo vanes cleaned, replaced control ring
03TDICommuter is offline   Reply With Quote
01 Jetta TDI, no power, but making 8.6psi boost steffen707 TDI 101 11 June 13th, 2014 04:33
Cold start, no power, still making boost steffen707 TDI 101 2 February 25th, 2014 10:56
Experimenting making some high power LED headlight retrofit bulbs...more MPG's?... josh8loop TDI Fuel Economy 15 September 12th, 2011 06:57
Power Steering really hard and making weird sounds ! VOLKSWAGEN_JETTA_TDI VW MKIV-A4 TDIs (VE and PD) 4 January 24th, 2010 00:59
Page generated in 0.11598 seconds with 12 queries
[Output: 64.62 Kb. compressed to 57.93 Kb. by saving 6.69 Kb. (10.35%)]
