Den
- Joined
- Apr 15, 2001
- Location
- Central Fla.
- TDI
- 2001 Jetta Baltic Green & 2015 Passat SE TDI 6 spd. auto.
Are there any issues with the newer 2.0 L engines clogging up like in the past ?
I was thinking DPF clogging, which the emissions warranty would cover.What are you referring to when you say "clogging up"?
Good ol' intake clogging. I'm not sure if that is what the OP was referring to but it is what I first thought of. Next it was "No intake clogging, just HPFP explosions." To be fair, while HPFP failures happen, intake clogging was going to happen.Heh, the pre-ULSD days of intake clogging seems like child's play compared to the potential problems the newer cars have. We left the intake clogging from the past, in the past. Welcome to 2007.
It is all relative. Eventually everything will fail.so you're implying a HPFP will never fail? even those too will fail eventually.
Lucky us it's just been extended beyond the miles we've been seeing.
